Old 09-12-2004, 12:14 PM   #1
gealto's Avatar
Tire Pressure
I have split rim 9.00 X 20.00 tires that are stamped "load rated 5150 lbs single at 95 psi". I've been inflating these to 95 psi. Is that correct, or should I use a lower setting. GVW is 20500.
Thanks in advance.
Gealto
gealto is offline   Reply With Quote
Old 09-12-2004, 12:32 PM   #2
Steve's Avatar
That sounds correct, I don't have my 8.25x20 split rims anymore and now have 10R22.5 and they are supposed to be inflated to 100 psi
Old 09-12-2004, 04:20 PM   #3
Firearm's Avatar
Send a message via ICQ to Firearm Send a message via AIM to Firearm
No wonder they put those bad boys in a steel cage the first time they inflate them. Imagine if something came apart at that psi.
Firearm is offline   Reply With Quote
Old 09-12-2004, 05:06 PM   #4
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
School bus tire pressure
I just read something about this the other day in the mechanical forum on http://www.schoolbusfleet.com There were differing opinions on the issue. These facts are not subject to dispute: overinflation causes excess wear on the center of a tire's tread and causes a rougher ride for the vehicle; and, underinflation causes excess wear at the tread edges and causes excess heating of the tire.
One person pointed out that the ratings on tires are the *maximum* pressure at the *maximum* load rating for the tire, and said that in the fleet he mechanics for they use 75PSI in their tires. I don't know if that's good or not, that's just what he said (as I recall it.)
One part of the discussion evolved around differing wear characteristics between tire manufacturer's products, something that would be unique to each person's situation.
Going outside, be right back.....okay, back.
My little Jeep Wrangler has 9.5" x 30" light truck tires on it. The lettering on the tires says that the *maximum* load for the tires is "1985 pounds at 50 PSI cold". I run the tires at 32 PSI, not 50. (No way my Jeep could carry 4 x 1985 pounds, at any PSI rating!) The tires wear evenly at 32 PSI. I had run the last set for a while at 40 PSI because I was driving many highway miles each day and wanted to get better mileage, but the tires ended up wearing down more quickly in the center, and so I then underinflated them to about 28 PSI for the last 20,000 miles of their life (I was still able to put 80,000 miles on the tires before replacing them.) They ended up with a really strange wear pattern, angular grooves of very worn areas all the way around the tire -- not cupping or feathering but grooves extending from one side of the tire to the other. Balance and alignment were maintained properly the whole time, so those factors were not primary causes of the strange wear.
I am not making recommendations, but it *seems* to make sense to me that if a bus is used in a capacity wherein it does not approach its maximum weight, there is no need to manage the tires as if they were carrying the maximum weight. If the GVWR for the bus is 26,000 pounds and its completed actual gross weight is only 18,000 pounds, it doesn't make sense to me (from a purely theoretical standpoint) to treat the tires as if they were routinely carrying 26,000 pounds. Advice from a competent mechanic, the vehicle manufacturer, and the tire manufacturer should all be considered in making any decision about how to manage the tires' inflation.
But as much as tires cost, it seems to be a good idea to get the most mileage out of them possible!
YMMV, I'm just a wannabe and have no practical experience. Correction and edification always appreciated.
Eric von Kleist is offline   Reply With Quote
Old 09-12-2004, 05:42 PM   #5
gealto's Avatar
Thanks for the responses.
I found a tire load vs pressure chart at http://www.trucktires.com that shows 95 psi is approximately correct for a 20,500 lb vehiclle with these tires fully loaded if weight is equal on all four tire sets. When I put the machine on the scales and get the actual weight, I could maybe reduce the tire pressure a little. I just want to avoid over-inflation if possible, to soften the ride and even the wear. At 14000 lbs. net, that would read correct at about 75 psi on all tires. I would estimate my present weight is about that.
Gealto
Tire Pressure? TygerCub Conversion General Discussions 20 07-19-2012 08:11 PM
Air pressure tank leak down bapos Mechanical and Drivetrains 9 05-30-2011 05:26 AM
pressure tank cheezypsnookle Conversion General Discussions 6 04-17-2010 10:52 PM
Air pressure to the gas pedal WHISPERS Conversion General Discussions 7 11-12-2008 10:52 PM
Correct Oil Pressure cooter Everything Else | General Skoolie Discussions 6 01-09-2007 02:10 PM
