Old 01-08-2007, 02:45 PM   #11
Year: 1980
Chassis: 3 axle (10 wheel)
Engine: GMC 6-71 T
Rated Cap: 97
Send a message via MSN to Coalforge
When my work truck was replaced with a forest green instead of the lime green I found I could not keep my dark glasses above the visor. The dark green collected enough heat that the glasses would blister you. The light lime green was much cooler.
Coalforge is offline   Reply With Quote
Old 01-08-2007, 09:08 PM   #12
GoneCamping's Avatar
I have a similar experience to those posted above. When mine was still yellow, it got unbearably hot inside. As I was painting the roof white with some Kool Seal, about half way through the painting project I'd go inside and check. The ceiling was much cooler to the touch under the portions painted white than the area's still painted yellow. I just couldn't imagine having a black roof. I painted the whole bus white, but I'll be adding in some other colors in a yet to be determined paint scheme...but the roof will remain white no matter what the rest of the scheme turns out to be!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
this is Black Sunshine anarkeen Short-Bus Conversion Projects 9 03-05-2014 05:38 AM
Finishing Touches - dark wood?? uswiththebus Conversion General Discussions 2 02-16-2014 08:25 PM
Different colored light lenses Gearhead94 Everything Else | General Skoolie Discussions 1 10-21-2012 04:44 PM
BACK IN BLACK sloppyjoe68 Short-Bus Conversion Projects 8 01-12-2011 06:24 PM
Enough tint to tint your bus.1%VERY dark! Frank ZX Classifieds | Buy, Sell, Swap 3 08-30-2009 03:46 PM
