06-06-2017, 08:43 AM
#61
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Originally Posted by Tango
FWIW --- The DOD ran extensive tests on various brands of penetrating solutions and found that that the one that beat all the others...was a home brew.
1/2 Transmission Fluid
1/2 Acetone
You do have to shake it to keep it mixed but I have tried it and it does work like gangbusters.
I have seen that. I will try it.
06-06-2017, 08:46 AM
#62
And...the price can't be beat.
06-06-2017, 11:32 AM
#63
Originally Posted by Brewerbob
I think I've run out of Kroil but on the bus I haven't needed any. All the bolts that refuse to let go get cut.
+1 on that! Kroil is good stuff. +1 on destroying anything that's in your way, too, I suppose.
06-06-2017, 11:37 AM
#64
1/2 Acetone
There's a homebrew recipe floating around the home shop machinist community that's called "Ed's Red". That sounds similar, although IIRC Ed's has 3 ingredients.
Secret Agent Google yields:
CONTENTS: Ed's Red Bore Cleaner
1 part Dexron II, IIe or III ATF, GM Spec. D-20265 or later.
1 part Kerosene - deodorized, K1
1 part Aliphatic Mineral Spirits, Fed. Spec. TT-T-2981F, CAS
#64741-49-9, or may substitute "Stoddard Solvent", CAS #8052-41-3, or
equivalent, (aka "Varsol")
1 part Acetone, CAS #67-64-1.
(Optional up to 1 lb. of Lanolin, Anhydrous, USP per gallon, OK to
substitute Lanolin, Modified, Topical Lubricant, from the drug store)
06-06-2017, 12:30 PM
#65
I wonder how the ingredients of Marvel Mystery Oil compare to those two recipes.
06-06-2017, 08:03 PM
#66
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
One thing NOBODY's mentioned - an extension ladder! You'll need to get up once in while.
06-06-2017, 08:17 PM
#67
Chassis: Bluebird
Rated Cap: 72 pax
A good step ladder for the sides and to go through the roof hatch, at the least.
06-07-2017, 07:40 AM
#68
A frame ladder or one of the folder deals.
Horrible Fright $139.99 minus the 20% coupon.
06-11-2017, 05:32 PM
#69
Chassis: HDX
Engine: Cat C7
I just picked one up (17') at the orange big box store for $119. After the GI discount, it was only $112. AND it supports up to 375 lbs.
06-12-2017, 08:28 AM
#70
$99 at the Horrible Freight sidewalk sale. I did NOT buy one. I have a 6 ft A-frame ladder and a 16' extension so not sure I really want to buy one.
06-12-2017, 08:57 AM
#71
06-12-2017, 09:19 AM
#72
video
Lol. Nothing like some vintage '70/'80s videos.
06-12-2017, 04:43 PM
#73
Anybody ever actually work with one of these? I would think the form factor would be good for travelling use, but I don't know if they're worth the considerable premium in price. I did see one once that a home inspector brought out to a house I was considering, and it seemed sturdy when I climbed it (270 lb).
https://www.walmart.com/ip/ABN-Alumi...-max/169804134
06-12-2017, 05:05 PM
#74
Chassis: Gensis
Ooh... someone mentioned a prybar. Best tool I have, 8 foot prybar.. Nothing survives it... i managed to bend mine a little pulling a 15 foot tree out of the ground.
I shoved that prybar deep into the space between the floor and wood deck... Eventually the floor got the idea and started to come up easier cause it realized what was in store for it.
06-12-2017, 05:13 PM
#75
I just used my Prybar today... wheeling 450 lbs worth of transmission and jack on hot pavement was a tad tough for a 140 lob guy.. so I used a prybar to scoot it along. the little divets in the pavement will help it not be so slippery come winter
06-12-2017, 06:08 PM
#76
Chassis: Bluebird
Rated Cap: 72 pax
I have a similar set up. It is pretty convenient and sturdy. I don't remember where I bought it.
06-12-2017, 09:33 PM
#77
I had one of those ladders (as in the video) took so long to transform it from A to B, I got rid of it.
I've always referred to the long pry bar as a Johnson Bar. (you might imagine why)
06-13-2017, 06:48 AM
#78
Never seen one, never used one but that has cartoon sketch written all over it.
06-13-2017, 06:49 AM
#79
When pavement melts, it's time to consider moving!!
06-13-2017, 07:00 AM
#80
Chassis: Bluebird
Rated Cap: 72 pax
Or build a solar oven!
