Old 12-09-2018, 07:19 PM   #1
Year: 1969
Coachwork: GMC
Engine: 6v71 Detroit
Total body removal. skoolie to tinyhome
So, i have 2002 Thomas flat front 38ft skoolie. It's stripped out and gutted and prepped for my roof raise but, i've been thinking lots about just removing the whole body from behind the driver area all the way back and building like a hybrid skoolie/housetruck thing. A few reasons this SEEMS like a good idea to me is I live in Alaksa and will be traveling to my other home in mexico and i could much easier frame and insulate a home from scratch that would super efficient. it would give me much more flexibility for interior design. Also i'm not a welder so i will be able to do more of the work on my own.
However, i haven't been able to find like ANY info of people doing this with a skoolie. Is there something i'm missing here??
Has any one done this?? Please send any and all thoughts and comments please.
I will be living in the rig fulltime with my wife and pups and traveling all over this wonderful continent.
thanks for reading and i hope to hear from y'all!!!
JoshwarrR is offline   Reply With Quote
Old 12-09-2018, 08:21 PM   #2
RHOMBUS's Avatar
Chassis: Freightliner HDX
Engine: CAT 3126B250
The chassis manufacturer, Freightliner in your case I believe, strongly recommends NOT welding to or drilling through the frame members. You'll need to figure out how to attach the house portion to the frame using existing holes, or clamps.
I know next to nothing about construction of a house, but I'm pretty sure you'll need to really toughen up all of your joints and attachment locations since your "house" will be subject to changes in gravity from accelerating, braking and turning, unlike something sitting on a fixed foundation.
Your maximum legal exterior width is still going to be limited to 8'-6" unless they have changed that again for RVs.
I'd recommend against exposed wood for the "foundation" due to water being blasted at it from underneath the bus.
It'll be awesome to see what you come up with!
My project: The Cruel Bus
RHOMBUS is offline   Reply With Quote
Old 12-09-2018, 10:44 PM   #3
T-Bolt's Avatar
Engine: DT530
As a residential/ commercial contractor for 26+ years I can tell you that there are no building method in the industry that would even come close to the structural integrity of a school bus. Picture a building going through hundreds or even thousands of hours in a hurricane and earthquake at the same time. Stick with the bus. Hire someone to weld if needed. For efficiency use 2 inches of a closed cell spray foam. Those 2 inches will exceed residential building codes for most of the country.
T-Bolt is offline   Reply With Quote
Old 12-10-2018, 12:39 AM   #4
Elliot Naess's Avatar
Engine: 5,9 Cummins
An idea:
You can buy an old refrigerated semi-trailer with amazing insulation for a grand or two without the refrigeration unit.
Cut to length; clamp to bus frame with same hardware since many such trailers have cross-members under the floor similar to the bus body.
Make sure the trailer you buy has suitable cross-members, and also make sure it is not too tall.
THE HEIGHT IS THE BIG QUESTION. And some of these trailers are tapered, to maximize interior volume.
Modern trailers are 102" wide. "Way back in time" they were 96", just like the bus.
Elliot
Old 12-10-2018, 08:22 AM   #5
Chassis: B3800 Short bus
Insurance. You'll have a hell of a time getting insured, which will relegate the bus to cruising around the back 40.
Also, as was mentioned, conventional wood framing is not a great building method for a moving, flexing, rocking structure. RVs almost get away with it, but those vehicles are prone to leaks over the long-term.
body removal, housetruck, tiny home
