Old 02-14-2018, 07:46 AM   #1
Chassis: Blue Bird
Engine: 8.3 cummins
Tote a vehicle
Anyone dragging a vehicle behind their skoolie.. I am looking for a Cherokee to tag along curious if anyone had suggestions to make hook up simple and cost effective.. thanks
bman91 is offline   Reply With Quote
Old 02-14-2018, 09:43 AM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
The motorhome crowd has this down to a science. The better tow bars (Blue Ox, Ready Brute Elite, etc.) all make connect/disconnect a very simple, one person job. Takes me about 2-3 minutes.
Here is a four part post I wrote on towing my Jeep Wrangler a couple years ago:
Jeep Towing - Part 1 - JdFinley.com
I went with the Ready Brute Elite tow bar from N.S.A. RV Products and am very happy with it (lots and lots of miles towed). It is described in part 3 of the above posts.
An older Jeep Cherokee (and all Wranglers - I'm not sure about the newer Cherokee's) are excellent choices as they don't require any drive-train modifications. If you get one WITHOUT a steering wheel lock, you simply drop the transfer case into neutral, disengage the emergency brake, and off you go.
JD - Full timer out west
My Adventures & Build
