Old 09-15-2012, 06:34 AM   #1
Tow capacity of a school bus?
Do school buses have a rated towing capacity? I know equivalent class A RVs are generally rated as either 5,000 lb or 10,000 lb towing capacities. I was wondering if school buses have tow capacities listed, since school buses aren't originally intended as tow vehicles. I know they have load information pertaining to what's actually inside, but that's not applicable to what it can pull.
stonestatue is offline   Reply With Quote
Old 09-15-2012, 07:28 AM   #2
Year: 94
Coachwork: b/b
Chassis: tc2000
Engine: 5.9
Re: Tow capacity of a school bus?
my b/b will pull 10,000 lbs with no trouble .5.9 cimmins545 trans ,trailer with a car on it. use lower grears when pulling a mtns.
heck its a truck frame,if it can't pull 25,000 lbs ,don't get it...mine is weld to the frame so i can too take the rear bumper off,it a fe model,72 pass ,as 49 said ,don't just bolt it,i have it bolted and welded to so if one fails the other will do the job.and use grade 8 bolts only.....
ok 49 ,do i need to add any thing more ,,,
i was still a sleep...
keith is offline   Reply With Quote
Old 09-15-2012, 11:32 AM   #3
Part of your answer will also lie in the strength of the hitch you build.
Just dont bolt a hitch on to the back bumper without reinforcing it to the frame, as some older skoolies have a stamped bumper that will bend over time..
my current bus has a hitch solidly welded to a piece of frame rail which is welded to the bumper, and bolted undernieth to the frame rails on the side of the engine cradle. That way, i can unbolt the bumper and the frame bolts, as the bus is a rear engine.
Old 09-15-2012, 12:21 PM   #4
Rated Cap: 47
I've done some searching on this lately, as the Motobus is going to be a 4x4 towing bus due to a recently broken foot. I can't find anything listed for buses. I found a new f650 is rated at 33K gcvwr, I think a towing rating at 24.5K. One will loose some of that off course, with the bus weighing more than a standard f650, but this offers some perspective. I don't see myself needing to tow more than the load of passengers the old ford could carry, but plan on getting a brake controller. I'm a little uptight about things.
During my searches I came across a post made on a misc. forum about trucking back in the days of gas semi tractors. A guy posted he remembered pulling a 10K trailer hauling 30-40k of steel on a regular basis with an international loadstar 1800 gasser. Back then they used what they had and drove accordingly. Now, people think they need a tow rig big enough they don't know they're towing. A cousin of mine is also a good friend and pulls a near empty 7x14 enclosed trailer with a Cummins 2500 crew cab and stabilizer hitch. He swears his half ton 5.9 gasser isn't enough. HA
Motobus is offline   Reply With Quote
DT 360 oil capacity SeanF Conversion General Discussions 9 07-12-2021 02:42 PM
Whats the oil capacity of my bus? Spoon International | Navistar Drivetrain 7 03-18-2019 08:24 AM
Capacity and Bus Dimensions Seeria Conversion General Discussions 7 08-29-2017 05:22 PM
Tank capacity? porkchopsandwiches Plumbing, Water and Waste 3 12-12-2013 04:17 PM
Overall WVO capacity recycler Alternative Fuels | Electric, Propane, Wood & Biofuels 6 05-20-2009 09:50 AM
