Old 04-10-2018, 09:54 AM   #1
Travel seating for co-pilot, and younger travellers...
In looking at all these skoolie conversions, I am not seeing additional seating beyond dinettes, for our fellow travellers. It would seem a good long bus would tend to be well suited for family travels.... So the question is....
For those of you with families, and I am thinking about couples with small children (safety seat / booster seat size /ages....). What are you doing for safe, comfortable co pilot and young passenger seatign and restraint?
dbhost is offline   Reply With Quote
Old 04-11-2018, 12:47 AM   #2
Year: 2010
Coachwork: IC
Engine: MF DT466
Rated Cap: 81
I have seen some stuff on youtube,mostly the couch having belts installed and tied to the frame somehow toward the front. Seen some buddy seats on the pass side also. I get a little paranoid about this but then think about a rv that will crumble in a crash,at least bus has a little metal around them. I guess main thing is go about it wise and allways be alert driving.
Miles O Roads is offline   Reply With Quote
Old 04-11-2018, 08:52 AM   #3
Chassis: Saf-T-Liner MVP ER
Mine is getting a co-pilot seat and a dinette.
The dinette will be built around two of the original bus seats. They will have to be adapted a little to make them fit, but they are massively strong and I don't trust seats made of plywood and 2 x 4s to stand up in a crash. Seatbelts will be added to those four seats giving a riding capacity of six, all with belts.
I am helped by having coach-seating rather than standard bus benches, so travel will be comfy.
Steve Bracken
Build Thread
Old 04-11-2018, 09:56 AM   #4
I have a passenger seat mounted by the stair well, it has arm rests, and seat belt, it spins around, I also have a another single seat behind the drivers, arm rest and seat belt, it swings around, as well as seats at the table, if you check out my build you will see them.
Old 04-11-2018, 11:40 AM   #5
Actually, you just gave me a fantastic idea.... A co pilot seat rigged like yours, or at least similar. I would HAVE to have some sort of flip down "floor" for my wife to put her feet... and then a forward facing scissor couch with seat belts anchored to the support ribs.
Just FYI, I am needing to be safe, and complaint with child safety seat regulations...
Old 04-11-2018, 11:45 AM   #6
yup be safe, if you look you will see my grand son sitting with his booster seat, make sure you use grade 8 bolts when bolting seats to the floor, I do have a stair well cover that folds up
Old 04-11-2018, 12:08 PM   #7
Yeah, your build thread is kind of long, but I see it. Nice seats. Looks like you did what I was thinking. Grabbing the captains chairs (and in my case, folding / scissor couch and seat belts) from a conversion van. I figure I will put use the couch in a row behind the drivers seat against the wall, and have the hallway shimmy around it...
Old 04-28-2018, 02:30 PM   #8
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Anyone looking for safe seats - there is a guy who works for DishNetwork in Ceres, CA and he has 8 Ford Transit van seats that were taken out of the Vans when they arrived new a couple of years ago and stuck in a warehouse. They have the seatbelt thing that it clicks INTO on one side but you'd have to buy the other part. $100ea with the steel pedestal that makes them the right height. Ford Transit vans aren't terribly expensive so you could probably but the other part of the seatbelt new. Much safer than a lot of options and reasonable, too! I got the 3 seats that had integrated seats belts so it would be easier. They were listed on Craigslist about 2 weeks ago. If you can't find it I can look for his cell phone number. He even helped me load them in the car.
2martins is offline   Reply With Quote
Old 04-28-2018, 04:16 PM   #9
I kept one of the student bus seats with attached seat belts to use on one side of my dinette (facing forward) so have a stable safe seat to carry 1-2 passengers. It's reupholstered to match the home made bench with storage underneath on the other side of the table. The wood bench with cushions is attached with brackets to the same bolting system as the original bus seats and anchored to the floor.
ptge57 is offline   Reply With Quote
Old 04-28-2018, 05:08 PM   #10
2kool4skool's Avatar
Yes! Bolt only to the floor...NOT the frame. If you have doubt as to why, look at some school bus crash test vids.
Don, Mary and Spooky the cat.
