Old 12-19-2017, 06:08 PM   #21
Coachwork: No bus yet!
Originally Posted by Jolly Roger bus 223 View Post
Wear good gloves and depending on you and your manpower a good long sleeve shirt because a creosote splinter sucks and the tar used to need kero or gas to get it off?
+1 on the railroad ties and +20 on the sticky creosote.
Dunno much about buses, expert in giant sticky chunks of wood..
Nice cheap way to build a pad that will definitely support a bus for a conversion. Also good for stacking to level and/or shore up the frame, depending.
Did something similar, a load of cheap crush n run gravel for a level bed, then tossed the rr ties in. Had plenty of old canvas to put over the sticky ties when working.
JumpinSkoolBoy is offline   Reply With Quote
Old 12-19-2017, 06:23 PM   #22
Robin97396's Avatar
If you can buy the older ties, they had much less creosote remaining on them. It's all about using whats available in your area.
I'm not suggesting a plank road, just a tie parking pad. You might even be able to use a creeper.
Robin
Nobody's Business
Old 12-19-2017, 08:05 PM   #23
Chassis: Saf-T-Liner MVP
Engine: Cummins
The railroad ties are a great idea for the parking spot. I will definitely look into that as a possibility instead of gravel. My major concern was getting the bus to the parking spot. I cant build a driveway as it is in between 2 houses. was looking for a very temporary solution. I think i will try the 2x6's and see how they do. Probably move them throughout the process egyptian style.
dspizzle is offline   Reply With Quote
Old 12-19-2017, 08:10 PM   #24
Robin97396's Avatar
Those 2x6s likely won't hold up in soft sand. You could do the egyption thing with ties.
Robin
Nobody's Business
Old 12-20-2017, 08:18 AM   #25
Engine: Cummins
How do you think a bus would do getting up onto a tie. I don't really want to dig the temporary ones into the ground.
Old 12-20-2017, 09:10 AM   #26
Robin97396's Avatar
You could create a little ramp using some pieces of those 2x6s after they get broken from trying to drive on them.
Honesty I don't know how firm your soil is there. I've got a fairly light weight bus at just over 17k, but I get stuck easily in my own yard.
Robin
Nobody's Business
Old 12-20-2017, 09:19 AM   #27
Engine: Cummins
I hear ya! I think I have some good direction. Seems like a little trial and error is how Im going to need to proceed!
Old 12-20-2017, 02:59 PM   #28
Chassis: B3800 Short bus
Originally Posted by Brad_SwiftFur View Post
Pine 2x6's simply aren't up to the task of keeping you afloat in soft dirt or sand. You'll want to get 2x10's or wider, or a harder wood such as oak.
Agreed! It was a slip up before to mention 2x6s. I was definitely using 2x8s or 2x10s. Probably 2x8s. Whoops!
Old 12-20-2017, 06:18 PM   #29
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Robin, I gotta say- you are on a a ROLL !
Keep 'em coming.
