Old 09-26-2005, 02:18 PM   #1
Type of Oil?
I've got a 1989 Ford skoolie. I need to change the oil for the 1st time. What oil type should I run in her? Can I get the new oil filter at Wal-Mart or a traditional parts store?
http://www.bulletbus.com
Bulletbus is offline   Reply With Quote
Old 09-26-2005, 07:47 PM   #2
Steve's Avatar
Sometimes its written on the oil cap too.
Old 09-26-2005, 09:00 PM   #3
Unfortunately she is currently parked at a friends work and locked up where I cannot easily get to her. But it's a gas engine. It's a B700 with a 370.
Old 09-27-2005, 11:33 AM   #4
lapeer20m's Avatar
I believe regular car oil is acceptable for all gasoline engines, including those in heavy duty applications. When i first started in the fire service, we had a couple of gassers. They both used regular oil.
If you are unable to find any info on what weight is recomended, I would immagine that 10w/40 is a pretty accurate guess.
What brand you should use is like asking people if if ford or chevy makes the better truck....but i'll give ya my opinion anyhow.
i've always been a big fan of valvoline myself. I wouldn't try using mobile 1 synthetic. I love mobil 1, but it's really really good at leaking out! If you have a small oil leak with regular oil, it'll be much bigger with mobil 1. That's been my expierence. Penzoil is one of my least favorite oils.
I buy most of my oil at wal-mart. It's the cheapest place i've found.
Old 09-27-2005, 11:56 AM   #5
Steve's Avatar
I would say if you start with 10w30 and watch your oil pressure. If it starts to get low then use a thicker oil. Repeat until you find the viscosity your engine needs.
If your main bearings are worn you probably need to be running 20w50.
Old 09-27-2005, 03:41 PM   #6
How many quarts do these beasts usually hold?
Old 09-28-2005, 12:21 AM   #7
You can probably call a school bus garage and ask for a mechanic.
Greg Archambault will probably know for sure. You can get his email or phone number on his site. http://flbus.tripod.com
busone is offline   Reply With Quote
Old 09-28-2005, 08:59 AM   #8
lapeer20m's Avatar
check the level of the dirty oil before you drain it. If it's in the normal range thats' excellent.
When you drain the oil, just pay attention to how much comes out. IF two gallons comes out of the crankcase, put 2 gallons back in.
my first bus, which was diesel, holds 5 and a half gallons of oil.
Old 09-28-2005, 12:31 PM   #9
I'm a big fan of synthetics. They're much more durable that dino oil, they have much higher temperature tolerances, and they're always going to be "clean" and not break down.
With that said, if you do have any leaks, Synthetic will find its way out quicker than the dino oil
66 Chevy Skoolie
Used for Tailgating to Kansas State University football games!
The seats are out (except for two facing each other) and replaced with matching couches.
7000 watt generator powering 2 6500 btu A/C's
Rebuilt 350 puts the power down.
66ChevyTailgater is offline   Reply With Quote
Old 09-28-2005, 11:06 PM   #10
I am a big fan of synthetic as well. I run it in my car with just over 100,000 miles on her and still runs like new. I also like the better fuel economy. My old beater truck did not do so well with synthetic though. She leaked like a sieve before with regular oil and she pissed all over the place with synthetic.
Old 09-30-2005, 07:21 AM   #11
She ended up taking 11 quarts. We changed the plugs and wires, air filter, and dist. cap. She is running strong now!
Old 10-02-2005, 10:07 PM   #12
lapeer20m's Avatar
what did you use for oil?
Old 10-04-2005, 02:10 PM   #13
We used 10W 40 penzoil for industrial trucks.
I've never seen such nasty oil come out of anything.
Old 10-08-2005, 09:07 AM   #14
Coachwork: Ward Genesis
Engine: DT466/MT643
If that's a 370 gasser like you said, you probably overfilled it substantially...my B-700 holds 7 quarts.
Jarlaxle
Old 10-11-2005, 12:27 PM   #15
It is an 89 370 B700. I drained out 11 quarts so I put back in 11 quarts. Made sense to me.
Insulation Again!!! But what type rex_1_mn Conversion General Discussions 2 02-04-2013 12:56 PM
What type of bus to choose thesaltydog24 Conversion General Discussions 6 10-25-2009 10:03 PM
What type of paint to use butcher_boy Conversion General Discussions 1 09-09-2009 08:27 AM
type of oils icnivad Mechanical and Drivetrains 8 02-13-2009 09:56 PM
What type of Batteries? dlor1 Everything Else | General Skoolie Discussions 13 07-27-2008 05:39 PM
