Old 01-24-2018, 12:17 PM   #1
Engine: 8.2 Detroit Deisel
Rated Cap: 6 carbon units 1 drag car
Water Drain valve on Air brakes
Hi all,
Went and fired up the bus this weekend and hear a hissing noise once it was running and brake pressure was up.
I am showing 125psi on the gages so that is good. I crawled under where the hissing was coming from. I put my hand up to the noise and could feel it coming out from seal.
It appears this is a 2 piece part, a cast housing that the lines go to and a cast piece that looks like it holds the valve to let water and air out. The piece that the valve is in is cracked. I can see it the air is leaking out around that area.
So does anyone know where I can get one? or do I pull it and have it welded and machined? I would really prefer getting a new one and welding this one as a back up.
Thanks!!
produster is offline   Reply With Quote
Old 01-24-2018, 01:17 PM   #2
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Originally Posted by produster View Post
Hi all,
Thanks!!
Got a pic, or can you get a pic of it?
My be able to get the part from a truck supply shop.
Old 01-24-2018, 01:31 PM   #3
I will this weekend.
Old 01-24-2018, 02:14 PM   #4
Chassis: International 1753
Engine: 6.9 International
My wild guess is that the air dryer is leaking. You can buy rebuild/reseal kits for them. Or your governor filled with water and cracked. Hard to say without a picture.
Old 02-23-2018, 09:28 AM   #5
Sorry it took so long to get back but life happens...lol
here is a pic i took. hope it helps.
