Old 07-15-2017, 10:52 AM   #1
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Welder Won't feed
Hey all , I have a Lincoln Weld-pak 125 mig welder, It's happened again where the wire won't feed, Last time I took it in & was charged $150.00 & when I got it back it worked for about 5 min & stopped, I removed the wire feed hooked it up directly to a battery & the roller worked so I put it back together & it's been ok for the last couple yrs.
Well today I need to use it & once again it won't feed, Hooked the drive up to dc & it works, put it back together & it won't feed, I can hear it thunking when I hit the trigger, I can feel the relays switching but the wire feeder won't turn, Any ideas??
Old 07-15-2017, 11:11 AM   #2
Oh geez, I read online about someone who had the same problem & it was the heat switch, just went out & moved my switch & it works, set it back to where I need it & it works.
Old 07-15-2017, 11:37 AM   #3
turf's Avatar
gotta make sure its in neutral!!!!
Turfmobile Build Thread
