Looks like the dt466..mine looks like that. Can you clean otf that little tag on the valve cover? It will give you the specs.. What bus?
Edit.. The file name of the pic says DT466.
That tag will tell you the engine class.. And what the horsepower and torque is.. They had 2 different HP ranges.. Mine is the 215hp.. I believe the other is 250.. Do you know the tranny?
Originally Posted by o1marc
I was just checking, that's what it's suppose to be but it looked different than my google search showed.
Bus is 1000 miles away. I'll have tranny info on Mon., hopefully verifying it's an MT643.
