Old 12-07-2007, 09:11 PM   #11
the_experience03's Avatar
Re: What is WD-40?
Originally Posted by pete c
elliot, you will not be dissapointed. kroil flat out kicks the **** out of any other penetratin' earl I have ever used.
AGREED!
We get it at school through both the parts store and our chemical supplier. I can then buy it secondhand from my instructor. OTherwise there are a few outlets up here that carry it.
Old 12-08-2007, 11:12 PM   #12
Re: What is WD-40?
I had to look at work today and they do say that it contains petroleum distillates so that makes it atleast somewhat toxic in my book. Yep, I'm sticking with pretty smelling kerosene.
Another good penetrating oil I failed to mention is Knock'r Loose by K-W/CRC. It's no AeroKroil, but it's good stuff.
Old 12-09-2007, 11:14 AM   #13
KC10Chief's Avatar
Rated Cap: 60
Re: What is WD-40?
Just don't use WD-40 on anything that has rubber in it. It breaks down the rubber. I used some on a $2,500 mountain bike I had. Big mistake. I had to replace quite a few expensive bushings. Also, another great way to get permanent marker removed, is to scribble over it with a non permanent marker. Like a dry erase board marker. Then erase it right away. Comes right off.
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
http://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
