Old 10-17-2007, 05:30 PM   #1
What size bottle jack for bus?
I'm going to buy a couple of bottle jacks at Harbor freight to work on the bus. What tonnage are you guys using to lift your buses with?
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 10-17-2007, 08:32 PM   #2
lapeer20m's Avatar
Re: What size bottle jack for bus?
an entire 72 passenger bus weighs about 20K pounds. so a 10 ton jack should be more than sufficient, since you're only lifting a quarter or half of the weight of the bus at any given time.
make sure to get one with a long stroke. My bus was stuck in the sand and i had a bottle jack that only lifted about 4 or 5 inches. That wasn't enough to accomplish anything useful.
Old 10-17-2007, 09:03 PM   #3
KC10Chief's Avatar
Rated Cap: 60
I try to avoid that Harbor Freight crap, but you might be able to find a good bottle jack. The price difference in bottle jacks vs how much they can lift isn't much. I need to get one too. I'm just going to buy the biggest bottle jack I can get. Home Depot sells them, even Wal-Mart. They both sell bottle jacks that are big enough to lift a bus.
Matt
1993 International Carpenter 10 Window bus
7.3L diesel w/AT545
https://i74.photobucket.com/albums/i2...DSC02426-1.jpg
KC10Chief is offline   Reply With Quote
Old 10-17-2007, 09:08 PM   #4
KC10Chief's Avatar
Rated Cap: 60
This baby at Home Depot sells for $50. It's a 20 ton jack and should be able to lift two whole buses at once. I like to go overkill a bit. If you're only lifting around 5,000 pounds of bus, then you're not really putting a lot of wear and tear on your jack!
Matt
7.3L diesel w/AT545
Old 10-17-2007, 09:47 PM   #5
the_experience03's Avatar
Remember the HF rule of thumb that you half any listed capacity or specification to get an accurate rating. 20 ton sounds like a good choice to me.
Old 10-17-2007, 10:05 PM   #6
Engine: 7.3 diesel
I have two jacks one for travel and one for home. My home one is a large 5 ton floor jack which lifts anything I want to lift. In the bus I have a 20 ton bottle jack.
The Gypsy Jack Conversion - Take 2 mosdottir Skoolie Conversion Projects 6 01-21-2014 06:11 PM
changing tires w/o a jack tylermag Conversion Tutorials and How-to's 6 08-04-2013 08:05 PM
What type of jack/method do you use? heathnlaura Conversion General Discussions 9 06-26-2013 03:04 PM
how to jack up a shorty mcmasterp Short-Bus Conversion Projects 10 11-19-2011 05:54 AM
How to Jack up front of bus? jaredg Mechanical and Drivetrains 1 09-24-2010 10:46 AM
