Old 01-08-2008, 03:45 PM   #11
Re: What works to start a cold diesel engine??
in my limited diesels it is best to set up a block heater on a timer like lapeer20m was talking about. atleast use some sort of means for heating. i've seen diesels refuse to start on 90 degree days without ether when it was used too much previously. if you do have to use it it is best to only use it sparingly so you don't run into this trouble in the future. although of all my friends who have had diesel trucks the cummins' were always the best about starting cold. the ones that had trouble were typically gm6.2 &6.5 or early ford-navistars (6.9-7.3 idi).
unfortunately i fell off the bus. and now i'm not even near the darn road! ;) ;)
skooliechild is offline   Reply With Quote
Old 02-03-2017, 06:37 PM   #12
Don't use ether/starting fluid if your engine uses glow plugs. You risk blowing the head off as the ether ignites no matter where the piston is located in it's stroke. You can use it on non-glow plug engines or you can remove the glow plug relay and use it in a glow plug engine. Just don't use it with hot glow plugs.
bearhawk is offline   Reply With Quote
Old 02-03-2017, 07:15 PM   #13
Listen to bearhawk! He is spot on! Jack
diesel engine as apu adamanderr Conversion General Discussions 2 06-16-2011 08:58 PM
cant start my 91 international. how to push in "engine stop" frank-id International | Navistar Drivetrain 1 02-22-2011 02:21 AM
No start - Detroit Diesel 6.2L non turbo HELP! frank-id Detroit Diesel Drivetrain 15 01-29-2011 05:59 PM
Cold weather start the_experience03 Mechanical and Drivetrains 3 12-31-2008 01:54 PM
Replacing Gas engine with Diesel engine question ? soused moose Conversion General Discussions 7 03-17-2005 08:15 PM
