06-22-2016, 06:52 PM
#21
from my perspective I wouldnt wish having to dig down into an RE on anyone... from what i have seen popping open the doghouse on an FE gives pretty decent access.. at least for stuff on the top.. though ive never tried to change anyting omn the front of an FE like a water pump for fan clutch...
on my conventional wit ha mechanical DT. thus far ive found everything accessible.. I suppose the radiator and air shitters are a little less accessible because of the hood... but if I were doing a major repair id pull that off completely.. it doesn look hard .. conventioals with V-8s look a little harder to me to get to stuff on..
in general I find working on a bus easier than any automobile project ive gotten myself into other than the sheer weight and size of compoinents.. which juist means I need bigger tools than I had with my hotrods.. .. ie I dont think I ever had my 1"+ wrenches and sockets out hardly at all on a hotrod project.. yet they are out for lots of things on the bus...
the pure simpl;icity of a non-electronic bus is pure bliss to me for making repairs additions and mods...
some of the normal maintenance tasks look easier on an RE like changinf belts as they are right there when you pop the hatch... I casnt say what it would be like to have to pull a head or something on an RE as ive never attempted it...
06-22-2016, 07:59 PM
#22
Just from appearances, I'd guess a conventional is easiest with the rest of the (front, mid or rear engine) type D's being any varying degree more difficult in most cases beyond basic routine maintenance. And in almost every case I don't imagine most of us have the facilities or equipment heavy duty enough to remove and replace a power package regardless of where it's located. Suffice to say that unless someone here has the facilities that they're willing to make available to fellow skoolies, most of us are going to face the difficult decision to pay someone big money for this type of work or else end up taking a loss by just scrapping the entire vehicle if repair is beyond our budget. This is to say nothing of the expertise required to perform an overhaul by ourselves. I'm glad we have well experienced mechanically minded members here who share their knowledge but even that is only going to get a novice so far.
06-22-2016, 10:04 PM
#23
My FE bus doesn't seem like its gonna be too hard to work on. Its all mechanical. Not too many hoses and virtually no wiring.
Getting the engine out wouldn't be fun, though. But not really needed since it can be rebuilt in-frame.
06-23-2016, 10:46 AM
#24
Coachwork: Crown / Pusher
Originally Posted by RC000E
Well, your statement makes it pretty clear why they can be a hell of an expense for a private owner/party. Using proprietary cages and fixtures to work on the drivetrain is certainly not accessible to the owners, nor available around the country. If major problems occur, that's going to be a financial hit of pretty stout proportions...more so than your average rear engine or front engine bus.
I have a chance to get one now pretty cheap but, I'm passing on it.
You can always keep your eyes open for a RE Crown, tho they are kinda rare.
06-23-2016, 06:16 PM
#25
Okay, I have to say that this thread has me thinking I want to get my RE skoolie and do up some of the bodywork to reflect the Crown tradition. Is that sacrilegious?
06-23-2016, 06:34 PM
#26
It's your Skoolie, do what you want.
06-24-2016, 07:58 PM
#27
Coachwork: Ford
Chassis: E450 #Vanlife
Engine: 7.3 Powerstroke
Rated Cap: 25
Originally Posted by cowlitzcoach
I have worked on every type of bus out there including Type 'A' buses on van cut-away chassis, Type 'B' buses on P-30/Freightliner rail chassis, Type 'C' buses on conventional truck chassis, and Type 'D' buses with engines in front, in the middle, in the rear, on OEM vendor supplied chassis (GMC, IHC, Oshkosh, National, Spartan), and integrated chassis. I have worked on commercial buses, school buses, transit buses, and highway coaches. Of them all, the Crown and Gillig buses with the engines mounted in the middle are the easiest on which to work. Once the side rail is removed there is nothing to get in the way of getting to the engine. The only things that are not accessible from down below are the starter and water pump on the DD 6-71 engines. There is nothing on the Cummins that needs the floor boards taken up to be able to reach.
So what I am saying is yes it costs less to work on a mid-mount Crown or Gillig because you do not have to pay for a lot of time for a technician to burrow down through rat nests of wires and hoses to reach the engine. Except for a few of the late '80's vintage Crowns all were totally mechanical. And the later models that had electronics had DDEC/ATEC I/II which were pretty simple.
Changing the water pump on any Crown does not require the removal of the radiator.
Setting the rack, changing injectors, changing the pump, changing the turbo, changing the thermostats, etc. can all be done without spending time digging down through stuff to get to what needs fixing.
Crowns and Gilligs are like any other mechanical beast out there. They all have parts and pieces that are attached in an odd or different fashion. But once you learn the why then you can understand the WTH stuff. And most of the WTH stuff was done because it made things easier or made things work better.
IMHO the Crown and Gillig are still the crown jewels as far as buses are concerned. If you have an opportunity to purchase one that isn't all beat up it will be well worth it to you to do so.
Good luck and happy trails.
I definitely wouldn't have projected them to be easier in terms of maintenance and major overhaul. I haven't worked on them as you have though, so I suppose I stuck myself with the tough Rear Engine position. I have to admit though, I'm surprised that bus manufacturers, who very certainly market themselves on serviceability which leads to a companies incurred maintenance costs, haven't stuck with this mid-engine architecture.
I'm hesitant to buy into what you're telling me here, but you're experience preceeds you, so I'm weighing that information.
A converted skoolie mid engine Crown is the most affordable, easiest to maintain and most accessible...I didn't see that comin...I'll admit.
06-24-2016, 09:59 PM
#28
Quick answer as to why the OEM's don't make mid-mount engine buses is the engine manufacturers do not make those sort of engine applications any longer.
Back in the day, besides Crown and Gillig you had Twin Coach, Yellow Coach, and a couple of other OEM's that were making buses with mid-mount engines. In the truck world there were a lot of special application truck chassis that used mid-mount engines--fire trucks and garbage trucks come immediately to mind. In the military world there were also quite a few different applications that used mid-mount engines. Even the railroads used engines laid over on their sides to power commuter trains that were self-contained--the power unit was under the floor and the train did not need an engine to pull or push the car.
In today's world, right off the top of my head, I can't think of any application that uses an engine laid over on the side.
I would agree that a mid-mount engine in a bus is an ideal location--you don't have the engine dog house (with noise and heat) next to the driver and you don't have an engine compartment in the rear to keep you from having a full size emergency door in line with the aisle. Getting 16-rows of seats would be very easy in a 40' bus without any engine intrusion at the front or rear of the bus.
06-25-2016, 02:56 AM
#29
Maybe continuing cowlitzcoach's thought, manufacturers today want to avoid specialized application in favor of one size fits most. If the same engine and transmission can work in a conventional, front-mounted or rear-mounted transit style bus, this reduces the amount of components they have to source and the amount of spare parts a fleet has to maintain. If the only odd duck in your fleet is this mid-engine bus with specialized parts required, even for all of its pros and popularity it still ends up being an administrative headache to maintain.
06-25-2016, 09:51 PM
#30
Rated Cap: 37,400 lbs GVWR
I have a Crown Supercoach II, and so far I've not had any problem accessing whatever needs attention in the engine room. The air compressor and hydraulic pump at the rear of the engine are easily reached through the access hatch under the rear seat, and everything else is easy to get to. I recently rebuilt the Jake brakes and reset the DDEC injectors' height, and even the driver-side bank wasn't too awkward to reach. If I had to take the engine out, it just slides right out on a cradle - all I would need is some wooden cribbing and a forklift to make it easier. I have friends with mid-engine Crowns and Gilligs - the biggest problem I see with them is that they get damnably dirty so close to the road.
Give me an intelligently-designed pusher bus any day!
And just in case any long-time Skoolie readers here are wondering, I just rejoined this forum after a few years of absence. My bus is still a perennial work in progress, but it now has 2kW of solar panels on the roof to give me free power from the sun. My current project is to recore the radiator and replace the fan and hydraulic fan motor - always something to do!
06-26-2016, 06:40 AM
#31
What in your opinion would make an intelligently-designed pusher? Just so we know what to look for or what to avoid... Still being in the shopping stage myself I'd like the feedback from current/past owners to what headaches they've endured so I know if I have the patience to endure the same. I also have some ideas myself but may find they are impractical or ill-considered once neurons meet reality.
06-26-2016, 03:20 PM
#32
Detroit 671N info?
Hey Everyone,
Thank you for all of the discussion. I love to sit back and listen to folks who are more knowledgeable than I am on a subject discuss it. Educational and entertaining
I have put many miles on DD 2 strokes and they hold a special place for me. However, I have never even seen a "pancake" 671.
I have been searching for details regarding the difference between the regular 671 and the "pancake". I would guess from DD practices that parts commonality would be good. Just guessing though.
How about parts availability?
Is it likely that I may find a Crown with a factory 671T or TA?
Lastly.... I am eyeballing a couple of Crown's that are equipped with 5 speed manual's. Neither seller can identify what transmission it is. I am guessing that it is the Spicer MD 5 speed??? What can you all tell me about this trans? How about swapping in a 7 or 9 speed?
06-26-2016, 04:28 PM
#33
Year: 1975
Chassis: Gillig
I have been very happy with my rear engine Gillig.
Most everything you normally need to get to can be accessed with your feet on the ground.
I've swapped out both the engine and transmission, 1160 to 3208T and Spicer 5 speed to RTO 610. Neither swap was terribly difficult or required any out of the ordinary equipment.
Just a little creativity.
In my opinion an RE bus is the best choice for a conversion, but a mid engine could be interesting as well. Especially if you are looking for horsepower, I think some fun could be had with a pancake Cummins.
I can't think of any headaches related to the rear engine design.
Other than ease of maintenance the best thing about a RE bus is peace and quiet.
06-26-2016, 07:35 PM
#34
I would look for ease of maintenance and servicing - everything that routinely needs to be checked or replaced, such as air cleaners and valve adjustments, should not need lots of other unrelated things to be removed or disassembled first to get to them. There should be space to work on almost anything without constantly skinning your knuckles or having A Bad Day. Unrelated to whether it's a pusher or not, the main junction box is also a good indicator how well the bus is put together and how easy it will be for you to work on it - if the wiring is a god-awful spaghetti mess of unlabeled and un-color-coded wires going hither and yon, with no apparent logic to how it's been planned, you can assume you'll have a big job ahead of you if anything needs to be rewired and changed.
Pushers generally make the best platforms for serious conversions because almost all the space forward of the rear axle is available for conversion. It makes it much easier to plan bathrooms/showers/kitchens and to keep the plumbing simple when tanks can be located where you want, not where the bus dictates. Plus, pushers drive well, quiet and smooth riding, almost like a "real" bus such as an MCI.
I like my Crown, but I almost bought a Thomas WestCoastER when I was looking - that again would have made a fine conversion platform. Crowns are, as others have said, simply the best school buses ever made, but that's just my opinion!
06-27-2016, 05:10 AM
#35
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I really like my Amtran. I have access to the entire engine, and the full size radiator is a big bonus. Although, if I could do it all again, I'd get one with an MD3060 and DT466
06-27-2016, 05:32 AM
#36
That radiator is in the back wall, right? Does it attempt to pull air from the rear of the bus which would be a low pressure zone anyways or does the fan push engine compartment air out through the radiator into the area behind the bus? I've looked at that versus the diagonal mounted radiator in a Thomas RE and wondered which would offer better cooling because at least the Thomas catches outside air from the side of the bus but then it's hard to figure out where it exits the engine compartment except just to get forced downward and out like a conventional. However it seems like if the IC/AmTran design has the fan pushing hotter air from the engine compartment through the radiator into the low pressure zone at the rear of the bus then it would run hotter by nature or maybe this has been compensated in the overall design.
06-27-2016, 08:41 AM
#37
Engine: T444E/AT545
Rated Cap: 75
I think it's been compensated for. There are two very decent sized fresh air intakes on right behind the last row of windows (which also includes a 6' tall air intake for the motor), plus the whole engine compartment is open to fresh air from below as well.
06-27-2016, 09:15 AM
#38
Engine: 8.3 Cummins ISC
Rated Cap: 75
One nice thing about the International pushers is that they come with two huge air intakes on either side of the bus. Bluebird and Thomas have much smaller intakes that don't pull in as much air.
06-27-2016, 02:20 PM
#39
Detroit 671N info?
Hey Everyone,
Any info?
Thanks.
S.
06-27-2016, 02:56 PM
#40
Cool! (Pun somewhat intended) See to me that's good stuff to consider in order to ensure the suitability of the bus for its second life. I appreciate both your feedbacks on that.
