Old 08-22-2019, 11:07 AM   #1
Chassis: Carpenter SB 2508
Engine: Navistar DTA360 disel inline 6 cyl, 5.9L
Smile window gaps
Hi Bus Gurus,
I need some advice. (Before you ask, yes, I read the threads on window leaks & sealing.)
To test my methods, I pulled out a window, removed the old bytul tape, cleaned all edges on the window & bus frame, applied new bytul tape (2 -3 layers) on all edges, & put the window back in. Well there is still a 1/4" gap at the top, and tiny gap along the bottom.
Can I just squirt in 3M Urethane 550 into the gaps? If not, what should I do to fix the gaps?
Thanks!
Kathy K
Kaklehr is offline   Reply With Quote
Old 08-22-2019, 01:06 PM   #2
Coachwork: Blue-Bird
Chassis: TC RE 3408
Engine: 5.9 Cummins 12V Mechanical
I haven't done this yet, just getting ready to, probably next week. But I also have read a lot of threads on this forum about resealing windows, and I think most people put caulking in after a good cleaning and just before reinserting the window.
I don't remember reading anything about using butyl tape for this job. Upon recommendations that I read from several threads, I have a dozen tubes of this stuff and intend to use it for the recaulking:
https://www.amazon.com/gp/product/B07196HTBY/
Hopefully someone who has actually done this will step in and we will both learn something.
gs1949 is offline   Reply With Quote
advice needed, window seal
