Old 10-22-2019, 06:26 PM   #1
Year: 77
Coachwork: Gillig
Engine: 855 Cummins big cam
Rated Cap: single axle
Window Glass
My RV door on my bus has plexi for the glass. I can't see anything through it, and that is what I have to look through to check traffic. Can I just buy some window glass and cut it or is this something best left to a glass shop? I'm assuming it has to be the kind of glass that crumbles if it breaks.
wireguy is offline   Reply With Quote
Old 10-22-2019, 06:40 PM   #2
Yes, if you're going to use glass, use tempered glass.You could cut it yourself if it has square corners. Radiused corners take some practice. Personally I would use a piece of Lexan, It can't break, and is easy to cut to fit.
Old 10-22-2019, 06:50 PM   #3
Tempered panes 8x16 are about $60 each
You could probably do lexan for 25
Old 10-22-2019, 10:20 PM   #4
Year: 77
Coachwork: Gillig
Will Lexan yellow? I don't know for sure what the (non-glass) stuff is that's in there now but it has way darkened up. That window is all I have to check cross traffic to my right so it has to be clear.
Old 10-22-2019, 11:05 PM   #5
No, it doesn't yellow. I ran it as race car windows for decades.
Old 10-22-2019, 11:16 PM   #6
Year: 77
Coachwork: Gillig
Doesn't yellow. Sweet. I will look in to that.
