Old 11-08-2006, 11:46 PM   #1
frank-id's Avatar
Ya wanna know about batteries? Super good reference site
http://www.marine-electronics.net/techa ... _faq.htm#6
Frank
Old 11-12-2006, 06:36 PM   #2
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
restoring sulfated batteries
has anyone ever emptied the fluid (electrolyte ?) out and replaced the with distilled to restore the battery? This is better explained if you follow frank's link. I have numerous 6v batteries that are having trouble holding a charge and am thinking that they may be heavily sulfated and I am trying to avoid replacing 8 batteries.
Questions:
-what do you do with the old juice?
-what is a safe container to transport it?
-Do you just use distilled water to replace the existing fluid? Even to flush them out?
-Do you think it is worth purchasing a load tester, a digital voltage meter and a hydrometer? Or a combination thereof.
I have two portable intelligent chargers, and the fancy one in the bus. So I am good there.
The plan is to try to revive them, and see if it is a bad set or mabye all of them are pooched.
Thanks for the advice all!
-Richard
captainkf is offline   Reply With Quote
Old 11-12-2006, 07:41 PM   #3
the_experience03's Avatar
The electrolyte doesn't wear out or go bad. It is more than likely that your plates are toast. Replacing the fluid with distilled water would leave you with a pretty useless battery. Without acid, the battery will not function. Topping them off due to losses from evaporation with distilled water works because the acid is still in the battery and you are simply bringing the actual level back up over the plates.
That said...if you want to make the acid safe for transport, you simple need to pour a base into it. The easiest and cheapest way is to just mix it with baking soda. I do not, however, know if it is safe or legal to pour down the drain then. You probably should just contact the local waste managment department.
Just about everyone has an opinion on how to properly test a battery. I work for Batteries Plus so I can give you a quick run down of what we do. A lot of old timers will swear by hydrometers, but the only time we use one is to find a bad cell. We mostly just use it to make sure all the cells are equal. A digital voltmeter that goes out two decimal places is extrememly useful for finding the state of charge of the battery as long as you are sure you are checking it correctly (no draw, no charging, and not a surface charge). The only way to actually test the condition of the battery is with a load tester. A battery showing 12.65 volts might have a 100% state of charge, but but could be bad because it lacks the ability to maintain that charge when a load is on it.
Carbon pile load testers are the best, but are prohibitively expensive for the average person, but certainly are the best. The smaller handheld ones they sell at most parts stores work just fine for most people. If you havea Batteries Plus in your town, you can just bring the batteries there and they will test them for you for free. Just make sure that they are fully charge first because a flat batttery can't be tested.
Old 11-13-2006, 10:33 AM   #4
lapeer20m's Avatar
you try using a smart battery charger equipped with a desulfation mode?
Old 11-13-2006, 02:14 PM   #5
Deltran chargers (Battery Tender)
New/old good bus net site frank-id Everything Else | General Skoolie Discussions 5 06-25-2012 07:54 PM
Radiant Floor Heating Reference zim Heating, Cooling and Appliances 16 01-08-2011 01:41 PM
Are these batteries any good? Diesel Dan Electrical, Charging and Solar 4 12-09-2009 05:35 PM
Seeking a good reference on compressed air systems dentarthurdent Conversion General Discussions 9 12-06-2007 04:28 PM
Good site for those of you with gassers the_experience03 Everything Else | General Skoolie Discussions 0 02-08-2007 12:23 PM
