Old 09-03-2017, 07:59 PM   #1
You guys with trailer hitches....
How do you keep diesel soot off whatever you're towing?
I want to pull my boat... But I don't think the white hull is going to be happy with me!
Old 09-03-2017, 08:22 PM   #2
And before any of you purists start up... It's not beached on sand! It's pulled up on a submerged rubber horse stall blanket.
Old 09-03-2017, 09:35 PM   #3
bigskypc50's Avatar
Coachwork: AMTRAM
Chassis: INT
Rated Cap: Big Girl
My tail pipe comes out side just in front of the rear axle so it's not a problem when I tow, but if I did have that problem I would look for a tip to redirect either more down or left or right.
bigskypc50 is offline   Reply With Quote
Old 09-04-2017, 09:00 AM   #4
2kool4skool's Avatar
Don, Mary and Spooky the cat.
Old 09-04-2017, 09:32 AM   #5
Chassis: IH
The exhaust on my bus appears to have been redone at some point. It exits the driver's side, in front of the drive tire.
Old 09-04-2017, 10:36 AM   #6
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Took a short piece of stack off the top an old straight truck exhaust, cut a short piece off the end of bus and welded it back on on a 45* angle. Seems to have worked, towed a trailer twice now with a white and a yellow ATV on two different occasions...no soot that we noticed.
