-   Classifieds | Buy, Sell, Swap (http://www.skoolie.net/forums/f14/)
-   -   Many parts available (http://www.skoolie.net/forums/f14/many-parts-available-11026.html)
ScottT 05-22-2015 01:04 PM
Cord Caddy 12v powered cord reel, 50 amp service, cord and plug included
Allison MT654 5 speed, lockup torque converter - all mechanical, ideal replacement for a AT 545
Ring & pinion gears for a Rockwell SQHD differential; 3.55 and 5.29 available. I also have a carrier for the 5.29 gears
Leather swivel recliner.
Xantrex Freedom 458-20 inverter/charger.
Pictures available.
Make good offers, located in SE Wisconsin.
crazycal 05-23-2015 01:58 PM
What was the trans behind?
ScottT 05-24-2015 06:40 PM
Trans
The trans was in front, it was a pusher.
Does it make a difference?
Thanks
Scott
crazycal 05-24-2015 07:42 PM
I meant what engine.
ScottT 05-28-2015 05:58 AM
Engine
Sorry.
903 Cummins.
Thanks
crazycal 05-28-2015 11:10 AM
Don't think that will work for me.
ScottT 05-29-2015 07:48 AM
SAE bellhousing
It's an SAE bellhousing, #2 I think.
crazycal 05-29-2015 10:17 AM
It's not just the bell housing size. They are set up internally for different engines based on rpms and gas or diesel.
zedster 09-11-2015 07:37 PM
Do you still have the Xantrex Freedom?
nat_ster 09-11-2015 08:25 PM
Thanks
Scott
No, the transmission used on rear pushers are the same as the front engine buses.
The rear differential or axle is where the difference is. The rear engine buses use a revers ring gear, and a flipped center pumpkin.
Nat
