-   -   Board up the side door (http://www.skoolie.net/forums/f11/board-up-the-side-door-11417.html)
sproutroot 07-14-2015 08:41 AM
Anyone ever boarded up the side door, and used only the rear door for an entrance?
My shuttle bus' side door and steps are pretty rusted and busted. They're on their way out. Thing is, replacing them with a well-insulated setup is expensive, and they're in the way of my intended floor plan anyway.
I figure if I board them up and put a window in so that my vision isn't totally obstructed, I'll be much happier with the interior space.
I could even [temporarily] use the steps as a battery compartment until I cut them out for more ground clearance.
Does anyone think this is a big no-no? I just haven't seen it anywhere, and that worries me a little. :hornet:
family wagon 07-14-2015 08:48 AM
That's my plan. I'm in it pretty deep, though: I'm doing a roof raise and entirely replacing the exterior sheet metal. My bus has transit-style windows which I'll be shifting forward. Originally there was the front entry on the right and a small window beside the driver on the left. Behind those, on both sides, were windows that spanned two between-roof-bows spaces. The door and driver window are both out, and I'll be shifting the big windows forward one bay to fill the space.
sproutroot 07-14-2015 08:48 AM
That is deep!
My E-Super Duty has a driver-side entrance, so the cab will still be easily accessible without it.
wmkbailey 07-14-2015 09:04 AM
I know a few people on here that removed the front door and moved it to a mid door. That way they had better space up front for their wife. I kept my front door and use the rear for safety, in case of a fire we have two exits.
sproutroot 07-14-2015 09:06 AM
Well this is encouraging guys, thanks. I'm pretty new here, so I guess I just haven't come across anything like that yet.
maggiemae 07-15-2015 01:15 AM
For our conversion right now, we are going to have the back door be very seldom used... our bed is right by it. We have a wood stove... and even if we didn't... its always a good idea to have more than one way out. Lord knows I couldn't get my butt out of those little windows very easily, lol. That's the only concern I would offer. Does your bus have a ceiling emergency exit?
nat_ster 07-15-2015 01:21 AM
I moved my door midship.
I used a steel, foam core, residential entry door, hung in a custom frame I made from 14 ga galvanized sheet steel.
Pics can be found in this thread.
http://www.skoolie.net/forums/f11/th...ime-10138.html
I also raised the roof 23 inches and installed windows 4 foot tall by 5 feet wide.
Nat
sproutroot 07-15-2015 10:14 AM
Well my bus is pretty short, so I want as much side length as possible for my floor plan. I still have the driver's side door. There was a roof hatch. Still have the broken off door, the hole's been patched with a sheet metal cover. I imagine it's easily fixed.
sproutroot 07-15-2015 10:19 AM
Some pics of my bus from the welcome center. This is how he sits now, haven't torn into him yet.
http://www.skoolie.net/forums/f6/hel...-vt-11395.html
sproutroot 07-15-2015 10:18 PM
I think I can reuse the windows from the door in the same place. Rather than buying a new window, I could just cut those to the right length, save some money, and preserve the look a bit to boot.
r_w 07-17-2015 09:23 AM
Could be done. Use that space under the floor for something-batteries, generator, water tank, etc. Most of those doors leak horribly anyway.
sproutroot 07-17-2015 10:02 AM
If my batteries fit there, I'll be using it for that at least temporarily. It really cuts down on my ground clearance, so I think I'll eventually cut the stairs out entirely. Eventually.
nat_ster 07-17-2015 10:11 AM
I cut my stairs out.
Now I have 16 square feet more floor space.
I never did like the idea of wasting floor space with stairs that can be outside the bus.
Nat
r_w 07-17-2015 11:26 AM
At least the bottom step. Building a trap door storage locker would be good, too. It depends on your weight balance and interior floor plan, but you can still get a foot of vertical space without impacting ground clearance.
sproutroot 07-18-2015 09:08 AM
I was thinking that it would be a cabinet accessed from the outside. If not for batteries, maybe it could be for tool drawers, or the generator, or insulate it and put in a water tank. Cut out the second step, turn it upside down, and weld or bracket it back in to get a box, rather than stairs.
Still think I'd rather have the ground clearance though, we'll see.
@Nat, I'm a slave to floor space.
milkmania 07-18-2015 09:16 AM
I know we're talking shuttle buses vs. conventional buses... but papabear had a pretty good build... so, I'd say just about anything is possible!
here
http://www.skoolie.net/forums/member...albums538.html
and here
http://www.skoolie.net/forums/member...albums495.html
sproutroot 07-18-2015 11:53 AM
That's a great example of what I'm talking about.
And what a great build!
Did he ever paint that rig up?
milkmania 07-18-2015 12:15 PM
dunno, I tried resurrecting the thread from the dead.....
http://www.skoolie.net/forums/f11/th...s-3501-10.html
sproutroot 11-09-2015 03:24 PM
1 Attachment(s)
I'm in the process of finishing this project up. I'd like to patch the hole (left after door removal) with a material that matches the rest of the bus.
It's a composite material consisting of two layers of aluminum sandwiching a core of something else. Does anyone know what it's called, or how to get my hands on some (by some I mean one 9'x3' panel)?
After some searching, I think my best guess may be to find a similar bus in a junkyard, and cut it up. However, that would take time, which is my most limited resource at this point.
Stan350 03-02-2018 01:45 PM
I think this is the type of material you are referring to:
https://www.ebay.com/i/142264365317?chn=ps
My dad used to work as a mechanic for a company that built canopies over the pumps at gas stations and they used something like this. I can't remember what it's called, I'm sure I'll remember in a couple of hours.
