-   -   Removed bus flooring. Ready to tackle electrical system- Help!!! (http://www.skoolie.net/forums/f49/removed-bus-flooring-ready-to-tackle-electrical-system-help-11855.html)
Brady78 08-26-2015 07:38 PM
Hello,
I'm really new at this. Just got a 2000 Bluebird All American bus. Started the conversion process and need help.
I removed the flooring to check for any signs of rust and take care of it.
Next I need to work on the electrical system prior to insulating the bus.
I am clueless about the process. Can anyone point me in the right direction?
What should I look for?
Comments/ Help much appreciated.
Thank you!
:Thanx:
somewhereinusa 08-26-2015 08:24 PM
Really? Do you think we are supposed to have any idea about what you are asking? We have no idea of what you are trying to accomplish. YOU have to have some sort of plan. I suggest you spend a few weeks reading old posts, get a plan on paper. No one is going to, or be able to, answer such a generic question.
Dick
Brady78 08-26-2015 09:26 PM
Dick
Hey Dick,
Thanks for the lecture and all the help. I appreciate it.
Sounds like someone needs to get some.
Brady
somewhereinusa 08-26-2015 09:43 PM
Wires.
Try asking well thought out specific questions.
I'm beginning to agree with Nat.
family wagon 08-26-2015 09:57 PM
Seriously though, "work on the electrical system" is fairly ambiguous.
The coach electrical system? I'm not sure there's any standard thing on that; it seems most of us just leave that stuff (turn signals, head lights, brakes, horn, charging system) alone. Usually the school-specific safety stuff has to be disabled or removed (red/yellow lights, swing-out stop signs, etc) but that seems to be different for each bus.
A 120 volt system? There are threads here for that http://www.skoolie.net/forums/f10/ho...ac-448-16.html and http://www.skoolie.net/forums/f10/rv...y-7862-10.html
A house dc system? I think there's a thread on that too, but as I recall there aren't the same degree of "standard/good practices" for dc as for ac.
I guess the first step is to define what you want the electrical system to do for you. Here on skoolie.net I've seen it run the gamut from an all-electric coach with electric instant/tankless water heater all the way to just enough solar and battery to warm a hot drink and run a few LEDs.
If you can kind of draw an outline of what you want an electrical system to do, then we can give more specific suggestions or feedback on how to get there.
crazycal 08-27-2015 12:06 AM
:banghead::banghead::banghead::banghead::banghead:
Red is positive and black is negative. Is this what you are looking for?
LRflip 08-27-2015 01:17 AM
Originally Posted by Brady78 (Post 121880)
Hello,
Thank you!
:Thanx:
Start by isolating and labeling all the wires you find. Figure out where they go, figure out what they run, label them simply, then figure out if you need them or not. This is where I would start.
More specific questions will get you more specific answers, just remember to ask before you F something up that you can't fix.
aaronsb 08-27-2015 03:28 AM
Actually, technically, well...sort of what I've seen is black is power and white is ground on bluebird busses.
But then all the other systems have other colors anyway.
Dragonpop 08-27-2015 09:21 AM
Wiring doesn't explain whether you are doing 12 volt or adding 120
volt house wiring. If it's 12 volt and your bus is new enough you can
go to Central States Bus Sales and download a wiring schematic for
your bus. This will show you what each circuit goes to in your bus.
When you look at wires in your Blue Bird you will find small numbers
on each factory wire which identifies the circuit they go to. If you don't
want to use that circuit you can remove the wire or re-purpose it for
something else you will use. The 120 volt side of wiring is a whole other
subject.
mrblah 08-27-2015 10:20 AM
You (OP) need to look at your bus like a house.
Ever seen someone build a house without floor plan and electrical plans? Sure you can, but you can't really asks someone for help if they can't look at what you have in mind...
Look at you conversion like a house.
What's going where, what type of devices (and power consumption it has etc).
Where are going the tanks and plumbing
etc.
You there is no 1 recipe because no one chooses a bus to build it like someone else's. They'd buy an RV...
Figure out a plan, then make an effort to sketch out a way to acheive it then double check with people here.
Right now you look like you haven't done your homework and no teacher wants to help someone who doesn't work on their own a bit...
