-   -   Bluebird T2000 Accordion Door Question(s) (http://www.skoolie.net/forums/f13/bluebird-t2000-accordion-door-question-s-13032.html)
lizzabus 02-06-2016 05:03 PM
First: Thank you SO much to all the wonderfully helpful veteran skoolies here. Your patience and willingness to share your knowledge and expertise is priceless.
My question(s): How in the heck do you get into a 1994 Bluebird T2000 with an accordion door (air opener)? I just pushed it open when I was looking at it but that seems rather crude.
Is it possible to lock said door? Or do I need to plan on replacing it with something else?
Thanks! I don't even know what questions to ask (and the proper terms) so I do appreciate your patience.
Lisa
Here's a pic of the door in question:
http://www.skoolie.net/attachments/p...9c1ef7fdaa.jpg
lizzabus 02-06-2016 05:06 PM
Another pic of the door:
http://www.skoolie.net/attachments/p...dfcc7531ed.jpg
CaptSquid 02-06-2016 06:05 PM
I would suggest either:
a. A lock and hasp on the rear of the door
b. A keyed drop bolt http://www.skoolie.net/attachments/p...728a548371.jpg
Scooternj 02-07-2016 01:56 AM
That's generally correct. There should be a manual release above the door to bypass the air line.
EastCoastCB 02-07-2016 07:59 AM
THis particular lock is made almost entirely of pot metal is sorta famous for breaking.
CaptSquid 02-08-2016 04:11 PM
Yeah, but something like this. Remember, a lock only keeps honest people honest. A determined thief will find a way in.
EastCoastCB 02-08-2016 06:27 PM
Right on.
That pot metal one won't require as much determination though!:wink1:
DRBW 02-13-2016 09:19 AM
I have the same bus and the lock pictured is the one I used... seems to work well. I can turn off the air valve at the top of the door and lock it from the outside. I had to drill the door out to install it.
lizzabus 02-13-2016 09:35 AM
DRBW: Would you please post a picture of your setup? I'd like to see where you put the lock. THANK YOU so much!!
opus 02-13-2016 02:47 PM
Is there not a lock at the bottom of the door?
