-   -   Wall framing failure (http://www.skoolie.net/forums/f13/wall-framing-failure-13658.html)
EricW 04-21-2016 01:52 PM
So I thought this was going to work nicely but not so much.
http://www.skoolie.net/attachments/p...b2e175e416.jpg
Seemed to make sense but as you can see the top 2x4 is not very stable. I was going to have the finished wall attached to those 2x4s and it works out that those would be flush. Now it is back to the drawing board. The only other ideas I have is to attach the studs right onto the ribs or put the one right under the window laying the other way... if I do that the ribs come out more than the stud and I'm unsure how to avoid thermal bridging. I think I'm just going to attach them right onto the ribs because I'm not sure what else could make sense. I would be left with a thermal bridge at every screw head on the framing if I go this route... I could do it where I screw the 2x4s in the way I was doing it and just use something to support the top 2x4 from turning. Any thoughts or ideas for me?
EricW 04-21-2016 01:54 PM
I suppose I could pre drill a hole partially into the wood and countersink the screw past the 2x4 where my finished wall will touch and just cover it with wood glue to avoid the screw touching the finished wall?
turf 04-21-2016 01:59 PM
run the studs horizontally and attach them to the ribs with long self tapping screws. use some liquid nails too, to help keep down rattles.
http://www.skoolie.net/forums/attach...3&d=1376135368
Docsgsxr 04-21-2016 02:02 PM
why not run the 2X4 vertically along the rib and drill into the rib itself with a self tapper? You could insulate with a thermal barrier bubble wrap before pressing the wood into it.
Just a thought....
Docsgsxr 04-21-2016 02:03 PM
LOL, too quick for me, but similar ideas!
EricW 04-21-2016 02:26 PM
Is thermal bridging really that big of a deal? Both of those scenarios would have every screw head touching the finished wall and I read a bunch of stuff saying you want to avoid that.
EricW 04-21-2016 02:29 PM
Also when drilling into the ribs are you still predrilling a hole? What happens if your screw lines up with a preexisting rivet hole?
EricW 04-21-2016 02:33 PM
And for the foam board insulation would there be any reason not to get it thick enough to fill the whole space between outside skin and the metal pocket from the seat rail?
EricW 04-21-2016 02:40 PM
I'm probably over thinking it. Running them horizontally and making sure the screw is sunk into the wood at least 1/8 inch is probably fine?
skoolie_n00bie 04-21-2016 03:21 PM
Apologies if you said so already, and I missed it...but are you planning on re-using the inner metal panel to cover the framing?
Usually, people cover interiors with plywood.
