-   -   A bus is never done-wheel arch rebuild (http://www.skoolie.net/forums/f27/a-bus-is-never-done-wheel-arch-rebuild-13860.html)
sdwarf36 05-14-2016 10:07 PM
When I first built my bus, I came across rusted out wheelwells. :facepalm: The 2-3" gap between the Ford wheel arches + the Champion box was filled--with spray foam. :sick: I'm sure it worked fine for years-but after a while it stays wet-and rusts everything out. I was able to chisel everything out and make a patch from the inside to seal things from the floor up-so I could start on the interior. I had this roll of plastic-pretty sure it was the sides to an above ground pool-nice thick stuff. I made a inner liner for the underside of the well-it worked awsome. :thumb: I'll get to the underneath when I can...
:eek: has it really been 8 years?
Originally the metal from the floor down was thin-maybe 22 gauge-backed by spray foam. Heres a chunk. http://www.skoolie.net/attachments/p...8c53088889.jpg
The lower piece slides under one above-with screws in the rub rail holding it all together. http://www.skoolie.net/attachments/p...2c87ebda74.jpg
http://www.skoolie.net/attachments/p...65cd74956e.jpg
This is what was left to a piece of 1 1/2"x 2" tube that was at the back of the wheelwell-that the mudflap attaches to. http://www.skoolie.net/attachments/p...f2e94f1301.jpg
I made the new piece out of 18 gauge. http://www.skoolie.net/attachments/p...5e6a24c000.jpg
There is all kinds of open space between the frame + the outer body. I always wanted to make some underbody storage. Now was the time. So I bent up a box. http://www.skoolie.net/attachments/p...2beffe4af2.jpg
Its 22"x 28"x8" http://www.skoolie.net/attachments/p...7d3f5be8d7.jpg
I bought a door on ebay from an overstock camper place-for $8.00! :dance:
http://www.skoolie.net/attachments/p...b6be895ab3.jpg
Its got 2 3/8" hangers on the back-and the box as a 1" lip catching the frame on the top-and new side piece all the way around. Its plenty solid. http://www.skoolie.net/attachments/p...f1a2586985.jpg
I brushed Ace hardware Rust stop paint on plenty thick. I plan on wrapping the bus so I wasn't worried about looks.
I'll get more pics when I finish up tomorrow.
Robin97396 05-14-2016 11:53 PM
Nice job on the box. Now that's the newest looking part.
RHOMBUS 05-15-2016 10:53 AM
Awesome find on the door, and nice assembly for the box! Some day I will get to my storage box fabrication, just not this day.
cadillackid 05-15-2016 10:57 AM
lookin good!! in the pic with the box mounted to the panel there is a nice trim there. . did you bend that in or is there something you used as trim pieces?
Docsgsxr 05-15-2016 11:10 AM
Excellent fabrication skills! Even though the box is smaller, it will give much needed space!
sdwarf36 05-15-2016 10:12 PM
I bent a 1" lip outwards on the box - and the lid had about the same sized trim around the outside. http://www.skoolie.net/attachments/p...561ef3a7c8.jpg Confession time-I screwed up making the box. :doh: It was supposed to be made out of 2 pieces. We have an old 8 ft brake at work-which no one has really used. I bent the big piece first-and it kind rolled rather than bent. :facepalm: Once I saw the issue, I adjusted the brake-its now good to go. But I didn't want to scrap a 42x22" piece of steel. So a little trimming + it got a cap on one side. I seam sealed all the edges-betting it will be plenty water tight.
I wish I could have made the box larger-but thats all the room vertically-and thinking one step ahead-I wanted to leave access to the rear leaf spring hanger-I know I'm gonna have to change them-someday. :whistling:
I made a new tighter fitting pool liner wheel arch. Siliconed the edges both sides. http://www.skoolie.net/attachments/p...0444df1f52.jpg I'm sure its gotta keep 99% of any spray from getting in any of the areas that could possibly leak.
Trying to wrap up the job, I ran into a problem. I reused the rub rails, and was going to get new rubber. I couldn't find anything to match-so I went to reuse the old stuff. It was about 6" short! :confused: Its 20 years old + pretty stiff. It must have shrunk once unscrewed-and it was cold today. Got to wait for a sunny day + hope I can get it in place.
