-   Classifieds | Buy, Sell, Swap (http://www.skoolie.net/forums/f14/)
-   -   Parts (http://www.skoolie.net/forums/f14/parts-13962.html)
pat2549314526@gmail. 05-24-2016 11:26 PM
Parts
Hope I do this right I am new here have a 88 chevy school bus and will not be needing the front or the motor so I have a 366 Cid with Trans and complete front clip Springs axel dash also have complete drive line and rear end asking 1200.00 for every thing was running January 2016 I also have window's seats and some parts for a international buss if you are interested e mail me at pat2549314526@gmail.com
Robin97396 05-25-2016 01:11 AM
Ah ha! Making a chicken coop huh? I knew someone would get around to it.
Brad_SwiftFur 05-25-2016 05:21 AM
Kinda makes me wonder ... assuming they bought a functional, running bus for this project ... why didn't they just buy a dead junker for less money?
pat2549314526@gmail. 05-25-2016 08:39 AM
It was fun as a driver but I am doing a conversion to make it a gooseneck I know to some of you that is taboo but me and the boys built it and it has been good but it will more sute my need as a pull behind don't need to be judged just trying to help someone that may meed parts the main coach will never be sold it will die with me
gizmoq 05-25-2016 06:55 PM
Originally Posted by pat2549314526@gmail. (Post 149783)
... a 366 Cid with Trans and complete front clip Springs axel dash also have complete drive line and rear end
What year was the bus manufactured? Which trans does it have? What mileage?
And, oh yeah, where is it now?
pat2549314526@gmail. 05-25-2016 07:10 PM
It is a 1988 chev the hood is off a 1987 gmc it has a 366 Cid with a 4bbl and all the emissions that came with it has factory headers and the transmission is the older style Alison also have a Alison out of a 91 int with a diesel has less then 2000 miles on a rebuild from a transmission shop we are in central Texas
pat2549314526@gmail. 05-25-2016 07:21 PM
Also the motor was replaced 1 1/2 school years before it was put out of service as per the school shop manager then I put about 3500 miles on it in the time I had it
Robin97396 05-25-2016 09:53 PM
Interesting. So no chickens huh?
Nobody is going to give you grief here about cutting up a bus. There are much worse forms of bus abuse identified here frequently. You're just entering new territory. These aren't generally trailer guys, but many things apply the same. Throw up some pics and listen to the banter. I think what's happening is you're blurring the line between skoolie and camper. You got to lay those new ideas on a bus forum slowly to not cause any hemorrhaging.
You want a bus but you don't want to deal with the engine. That would make a seriously heavy 5th wheel in my mind. I've seen that done actually, but sorry no photos from pre divorce era. It was actually from a time before 5th wheels in a land far, far away. Na, it was actually the back end of two buses put together kind of like a big yellow airstream trailer. Impressive looking on it's own and causes a certain amount of confusion at the same time from bystanders. You still have to pull it with something, unless it's more of a tiny home that you move just sometimes.
Are you unbolting the body and putting it on a 5th wheel trailer frame, or forming the bus frame into a 5th wheel setup?
It's a good idea. You're still reusing something that otherwise could turn into scrap. You've just found a way to not deal with an engine, and I'm sure you've stirred some imaginations here. You've probably got some kind of a re-licensing issue with that too. Chopped off the VIN#.
So, got a floorplan? Is the bus already built out as a camper and you're just trailerizing it? Inquiring minds...
pat2549314526@gmail. 05-25-2016 10:10 PM
Yes it is a full scale rv for the past 5 years it has all the things that a 5th wheel would have I was in the towing business for 15 years and also worked at a school as there mecanic so I know my way around a bus the bus did fine but like all drivers you have to take a second car if you don't want to be stuck at the park and the older buses do not have ac and in texas whin it is 100 degree it is hard on a long trip I repurpost 4 old wreck campers and have all the stuff in it frightliner microwave 2 ac roof mount and bathroom cabinets and beds got the weight down to under 11,000 lbs comparable to some of the 30 foot 5ers out there how do you up load pictures here new to site and don't know how it all works
Brad_SwiftFur 05-25-2016 10:51 PM
Please don't think I was judging you, I was more curious than anything. But having read the backstory, it makes more sense. If I had a couple dead 40' buses to work with (and a truck/trailer salvage yard to plunder) I might be inclined to merge 2 bus rear-sections to form a 50+ foot shell, probably doing a roof-raise on 80% of it ... the front would be set up in a typical 5th wheel, "Drop deck" fashion so I could move it with a road tractor ........ At some point it would probably be easier and cheaper to find an old moving van for a basis to work with.
