-   New Member Intros - Say Hello! (http://www.skoolie.net/forums/f6/)
-   -   Looking for the perfect bus. (http://www.skoolie.net/forums/f6/looking-for-the-perfect-bus-14127.html)
Shadowgathering13 06-12-2016 12:20 AM
I'm extremely exited about buying and renovating the my own school bus.
But I'm not sure what to look into first.
I obviously know a few things from what I've seen online and in forums but what should I be looking for most in a school bus before buying.
-Which is the best bus? International blue bird thomas cummings.
-Is there a certain amount of miles that you want to be under, or does it not matter as long as everything is in good condition.
-what is the longest and tallest school buses? The ones with the most room.make model year.?
-What type of engine should I look for in a bus, or what should I look for in general when buying.
I know there are auctions that can be found ocasionally I just so happened upon midwesttransit.com what is the best source to buy a bus.
What should my price range be? I've seen some skoolies that ppl bought for 2,000 that look great.
These are alot of questions that I'm sure I can find in forums, but there are so many questions that just branch out to more questions. Its hard to find the right immediate answer.
Carytowncat 06-12-2016 01:12 AM
Welcome!
How exciting to be searching.
A lot of my questions began to answer themselves over time and with research revealing information that helped me see what best fit my preferences.
Surely the right bus is out there looking for you too :) Good luck!
cowlitzcoach 06-12-2016 02:06 AM
When you ask which is the best bus you are going to get Ford vs. Chevy vs. Dodge answers that may or may not be helpful.
Of the newer buses I think the IC is the best, followed by Thomas, and followed by Blue Bird (I just have never liked Blue Birds).
Of the older buses the class act are Crown and Gillig.
Driven miles and engine hours don't mean a lot as long as the condition is good. A trip bus from a school in MT is going to have 2x to 3x the miles of a route bus but the trip bus miles are going to be easier miles than the route bus miles.
Type 'D' buses have the largest inside space from front to back.
Buses with 12" windows will have the highest headroom.
For all practical purposes you want to be looking to purchase a diesel engine. Inline 6-cylinder engines pull better on hills than V-8 engines and also tend to use less fuel.
As to make of engine you are back to the Ford vs. Chevy vs. Dodge discussion. The IHC DT360/466/530, the Cummins 5.9/6.7/ISB, and the Cummins 8.3/ISC are usually considered the best engines available.
Cat, Ford of Brazil, Mercedes-Benz, and Detroit can also be found under the hoods of school buses. For the most part they are pretty good engines but parts and service tend to be a lot more expensive and harder to find than IHC and Cummins engines parts and service.
There is no one best source for finding a bus. What you determine best for you may not be at all good for someone else. The folks at Midwest Transit are good people and won't steer you wrong.
As far as pricing is concerned it isn't much different from used cars--the newer the bus, the more options are on the bus, and the larger the bus the higher the price will be. The most expensive buses are going to be the 40' Type 'D' RE buses with big HP, highway gearing, and pass through under the floor luggage compartments. The least expensive buses are going to be the 12/13-row Type 'C' bus since they make about 65% of all school buses built.
Can you still purchase a good bus for $2,000.00--yes you can but not very often. Realistically speaking a good Type 'D' trip bus is going to cost closer to $7K than to $2K.
You may also want to consider purchasing one already converted. There is one that was posted here recently for under $15K that is pretty much turn key ready to go.
The one really important thing to be aware of is don't purchase anything that has any sort of rust problems. They cost a lot to resolve and never ever go completely away.
Good luck and ask whatever questions you need to make your project work for you!
Shadowgathering13 06-12-2016 11:07 AM
Thanks so much for all of the insight. That was so very helpful to narrow my search. Since I want to be prepared as much as possible for what to look into. I really appreciate the feedback. I've also seen a few comments on driver tranes? Know i didnt say that right. But what is this in regards too on a bus.
Scooternj 06-12-2016 12:03 PM
Just to tag on to the rust, stay away from buses from the Rust Belt. Yes, you can find one that's just got surface rust, but the older the bus, the higher the chance of more rust issues. Rocky Mountain states, the Southwest and West Coast are going to be your best choices for rust free
cowlitzcoach 06-12-2016 12:34 PM
When someone refers to the drive train that is usually referring to the engine, transmission, and rear end gearing. It can also include the suspension, axles, and brakes. The power package is another way in which the engine and transmission can be described.
For your purposes, any school bus is going to have an adequate drive train. The thing is, there is adequate which will get the job done and there is WOW! 47 MPH top speed is adequate and will get the job done. 75 MPH top speed is more than adequate and will get the job done much quicker.
The key to happiness down the road is getting the drive train that most closely meets your needs. Spending the extra $$$ up front to get the right drive train in the beginning will save you double or triple the $$$ difference between what will do and what is really wanted. Adding HP to be able to cruise at highway speed is not inexpensive. Changing gears to be able to take advantage of the increased HP is not inexpensive. Higher HP and faster top speed usually requires better stopping power. All of which is not inexpensive or easy. But can be found before you start in the right bus.
Shop around.
Ask questions.
Look farther away.
Be patient.
And always remember, if the "perfect" bus gets away from you there will always be another one down the road.
jake_blue 06-12-2016 02:14 PM
Just hopefully not broken down on the side of that road! Lol
Shadowgathering13 06-16-2016 08:58 PM
So here is another question related to the rust problems. How could you tell it has rust problems if it is not seen. Like, If you dont see it underneath or anywhere else until you pull up the floor boards and seats. Then what do you do if you find it there? is it too late to refuse to pay for the bus, or do you have to write some kind of contract stating that if you find any rust you will return it.
EastCoastCB 06-16-2016 09:29 PM
Visible rust usually indicates rust underneath. Looking at the chassis, rust will be pretty evident. Once you buy it, its yours.
Shadowgathering13 07-24-2016 05:34 PM
one more issue
I might have to start another thread for this if so let me know. Me and my significant other have been politely disputing the differences with a tiny bus home an Rv. Besides the price differences what are some of the best reasons you would want to own a Tiny bus home vs. an RV.
