-   -   Window (safety glass) in the front cap? (http://www.skoolie.net/forums/f13/window-safety-glass-in-the-front-cap-14619.html)
PNW_Steve 08-05-2016 12:24 PM
Hey Everyone,
I was fiddling around with some general design ideas (daydreaming) and had a thought.
When the right bus finds me I expect that there will be a roof raising in order. I was pondering the front cap and the thought of an arched safety glass window occurred to me.
Anyone tried this? What kind of issues/success did you encounter?
Thanks
Steve
BusFiend 08-05-2016 12:33 PM
You mean a separate window above the windshield or replacing the windshield with an arched variety?
PNW_Steve 08-05-2016 12:40 PM
Separate, above the windshield.
BusFiend 08-05-2016 01:12 PM
Great idea! I've only ever seen it done on coaches. The first thing is having a piece of safety glass cut to size; easy but not cheap. The second would be fabricating a mount. A shop should be able to do that for you. Again, probably not cheap. Then simply install the mounted glass in a pre-framed opening.
It would look wicked cool!
slaughridge85 08-05-2016 04:29 PM
Somebody on here did just that. There are pictures of it on a build thread somewhere... Can't remember which one though, an older thread I think.
PNW_Steve 08-06-2016 02:51 PM
I found some places online that will custom cut the laminates safety glass. The size is a bit of an issue with online vendors. I would have to make the window in two pieces.
The glass looks fairly straightforward but I have no clue when it comes to the frame/mounting.
Thanks for the suggestions!
