-   -   Out The Gate (OTG) (http://www.skoolie.net/forums/f27/out-the-gate-otg-15145.html)
yellowxj 09-24-2016 07:18 PM
Out The Gate (OTG)
Bought our 1985 Chevy Handicap Short Bus for $850 at the bus auction in the next county over in June. It wouldnt fit on my car trailer because of the steps so I had to drive it home . One of the rear tires has a bubble in it and one of the plug wires was bad so it felt pretty special hammering down the road at 60 .http://uploads.tapatalk-cdn.com/2016...6de74c57d0.jpg
The school have been using it as a service vehicle and the interior was already stripped of seats .
http://uploads.tapatalk-cdn.com/2016...92e9eb1f0d.jpg
http://uploads.tapatalk-cdn.com/2016...4b22c45867.jpg
We found only a little rust for such an old truck.
http://uploads.tapatalk-cdn.com/2016...cc31e6eb7e.jpg
http://uploads.tapatalk-cdn.com/2016...24e52b27cc.jpg
Sent from my VS986 using Tapatalk
yellowxj 09-24-2016 07:21 PM
We worked to get it ready for paint quick because we are an instant gratification family .
http://uploads.tapatalk-cdn.com/2016...3aaca65e8a.jpg
http://uploads.tapatalk-cdn.com/2016...d06c2ad4f4.jpg
http://uploads.tapatalk-cdn.com/2016...2b34ce90cf.jpg
http://uploads.tapatalk-cdn.com/2016...826e10c549.jpg
yellowxj 09-24-2016 07:25 PM
http://uploads.tapatalk-cdn.com/2016...2b3e6a282f.jpg
http://uploads.tapatalk-cdn.com/2016...f6404d5297.jpg
http://uploads.tapatalk-cdn.com/2016...8aa6616692.jpg
Mixxed our tractor supply white, ford blue, and safety yellow aiming for a teal or turqoise but settled for aqua blue-ish.
cadillackid 09-24-2016 07:29 PM
bad ass!! I love the old school van front!! was my fav style..
also love the retro aqua color!! cant wait to see it on the bus
yellowxj 09-24-2016 07:29 PM
http://uploads.tapatalk-cdn.com/2016...f4815b0de0.jpg
http://uploads.tapatalk-cdn.com/2016...0572e94818.jpg
http://uploads.tapatalk-cdn.com/2016...9baf36fb9d.jpg
http://uploads.tapatalk-cdn.com/2016...3348bba138.jpg
We got alot done today. Plywood in. Painted interior. Majes the last few weeks of scraping, sanding, patching, etc. Worth while.
cadillackid 09-24-2016 07:30 PM
p.s. i drive my bus at 55 all the time even though it will run 65-68... just feels better for a bus.. and whe nim on a road trip im not tryin to commute so I can enjoy and see the sights
yellowxj 09-24-2016 07:35 PM
Thanks! The hardener we got for the paint helped alot with the interior paint. Almost to quick.
We're aiming for a family trip with a flat towed jeep next summer. But we're hoping for some test trips this winter. We're in florida so we probably wont worry too much about heat.
cadillackid 09-24-2016 08:10 PM
is your dashboard heat-only? (void of dash vents).. if so I will tell you that the stock dash heater and defroster in those vans without factory air-conditioning was TERRIBLE..
I had a chevy VanDura like that.. it didnt take me long to tear that whole thing apart and outfit it with the air-conditioned version// (then again I wanted factory A/C)//
if you have or had factory A/C originally on the dashboard your heater will be pretty good.
cadillackid 09-24-2016 08:11 PM
your interior color is a lot like the factory interior colors on school busses.. its real close to my carpenter interior ceiling color.
yellowxj 09-24-2016 08:20 PM
Cool. We had dash AC and i want to fix that back up. Need to find a compressor and bracket for the motor. We did score an aftermarket bus AC that mounts inside and condensers with fans that mount underneath. Salvaged off a full size bus BUT theres not enough room underneath to mount the condensers. :( looks like I'll sell that.
Still not sure if we'll get the dash ac going and figure a mounting option for a 110 AC wall unit. ?
I told my wife it ironically looked like a bus color.
cadillackid 09-24-2016 08:27 PM
the dash A/C should be easy to fix up.. ive done a bunch of them... is the compressor actually gone? is that a Chevy 350?
if so we can easily find you a sanden 508 compressor bracket.. likely driver side as thats where the factory GMC compressor wouldve been.. it may have had rear A/C originally and someof it may already be under the bus... Transair used an up-under condensor that didnt face the bus skirt... and there would be multiple line T or Y fittings under the hood..
if it was dash only it would be void of that... building a tie-in system is a bit different than hsving a dedicated rear syste, using a secondary compressor...
if you are going to camp in it you will want aux A/C that doesnt require the engine to run so a camper-top unit on the roof or another type of unit out the back or underneath and of course a generator to run it..
seems a lot from florida on here.. I have homes in both columbus Ohio and st pete florida...
yellowxj 09-24-2016 08:44 PM
Thanks. It does look like they disconnected the factory ac and had some aux ac in the back above the door but theres nothing left but the hoses. I would be okay with Dash AC and a 110 mounted discreetly somewhere. I want to put a small back porch on it where I can hide a quiet 2KW generator to power the AC and some Outlets inside. I think I can run the 110 AC and Generator while going down the road if I needed extra Cooling . Would it work?
Jeep, bus, repeat.
oricha1984 09-24-2016 08:59 PM
bus looking good man ;-)
cadillackid 09-24-2016 10:32 PM
Jeep, bus, repeat.
people do it all the time.. run the genset and drive. im not sure if a 2K genersator will start up the compressor on a camper or window unit or not..
I have a 2 hose portable I use for when im stopped in my bus. (I have a regular large bus (short but tall).. I installed 2 A/C in it for the road but when im stopped i need air.. my portable unit is called a climax and it is soft-start.. (no surge current) but of course portable units tke up a bit of interior space physically..
the nost part of your dash air might still be there... and that GMC van style was made through 1995 so a lot of the hoses, coils etc up through the 92 model year would work to replace anything that the coach builder set up as a Tor Y under the hood... I yanked a whole system out of a junk yard for the Vandura i did... then i just bought new fan motor, heaster core and accumulator.. the rest was all used and that thing blue ice cold for many years after I sold the van to a friend.
Carytowncat 09-24-2016 10:57 PM
love the "imstant gratification family" lol
Welcome! Sweet bus and i third the color is awes. :)
yellowxj 09-29-2016 05:07 PM
http://uploads.tapatalk-cdn.com/2016...7ee561f67a.jpg
Conversion van seats $100. Will we use them? Probably.
Jeep, bus, repeat.
cadillackid 09-29-2016 05:40 PM
that back seat looks interesting... almost like a futon.. i could see 2 of those making nice dinette seats and then fold fown into a big bed.
yellowxj 09-29-2016 07:21 PM
http://uploads.tapatalk-cdn.com/2016...12f863ae95.jpg
Jeep, bus, repeat.
cadillackid 09-29-2016 08:13 PM
Originally Posted by yellowxj (Post 164893)
thats badass cool!! was that in the van or is that set up in your bus?
