-   New Member Intros - Say Hello! (http://www.skoolie.net/forums/f6/)
-   -   Proud new owner of a 1972 Gillig (http://www.skoolie.net/forums/f6/proud-new-owner-of-a-1972-gillig-15632.html)
Lokeasy 11-02-2016 05:48 PM
Hey everyone! Long time listener, first time caller. I am really thankful for this forum already because I would be more lost than I already am. The amount of knowledge here is staggering and most appreciated :bow:
I just recently picked up a 1972 Gillig (that was mentioned earlier this year to be for sale). It is already converted, but just a touch outdated. There are many many things I would like to do to it, so many I'm not even sure which way I'll go with it. I might completely gut and redo the interior to something more my style, or I might just make a few tweaks here and there as it suits my purpose.
I intend to live in it for as long as I can. As of now I'm in Texas, but plan to eventually make my way to Colorado. For that I imagine I'll need to gut it, insulate it, and probably update the wiring at a bare minimum (maybe split unit AC/Heat?). I don't need to rely on off-grid power for more than a few days, though the massive diesel generator has that covered. Short term, I'm leaving everything as is and feeling it out.
Some Specs-
Engine- Cummins 335
Transmission- fuller 10 split
Generator- yuuuuge diesel that is louder than my 7.3 powerstroke
Live Tandem Axle
Broken Dometic fridge (I hear this is their natural state)
Broken washer/dryer
tankless water heater (works great!)
Sleeps 10
I tried to attach pics to no avail
BernieMtnDog 11-02-2016 06:12 PM
I love the transits. Can't wait to see pics/how you update it!
Sent from my VS990 using Tapatalk
milkmania 11-02-2016 06:21 PM
Glad you made it here! :greetings:
Host your pics at a hosting site like photobucket, then post them here.
We're a simple people... We like pictures!
Alan N 11-02-2016 08:28 PM
You got a good one!
Enjoy!
Lokeasy 11-02-2016 09:28 PM
Thanks everyone! Here are a few pics
http://www.skoolie.net/attachments/p...caf811b595.jpg
http://www.skoolie.net/attachments/p...7698707e9a.jpg
http://www.skoolie.net/attachments/p...9673357d7f.jpg
http://www.skoolie.net/attachments/p...1507c7d763.jpg
http://www.skoolie.net/attachments/p...b1a9f3eaf0.jpg
1olfart 11-02-2016 09:57 PM
Nice Score!
milkmania 11-02-2016 10:01 PM
Green with envy
Swiping kitchen cabinet ideas:dance:
Carytowncat 11-02-2016 11:05 PM
Welcome!
Wow that's a bus! Beautiful. Oh and manual stick shift? sweeet! :)
cowlitzcoach 11-03-2016 01:17 AM
I am glad that bus has found a new home. It looks like you will be able to have a lot of adventures with that bus.
A couple of things you might need to know if you don't know about already.
First, if there isn't a pyrometer you need to install one. The 335 was a great engine with a lot of go to it. But, like all big Cummins, you can't get them very hot or you will burn a piston. Unlike a Detroit 2-cycle diesel that because of the design can't get too hot a Cummins will get hot very quickly on a good grade. I am referring to the exhaust temperature and not the coolant temperature. I had a Crown 10-wheeler with the small cam 262 with an Allison. I never saw the coolant temp ever get close to hot. But I saw the pyrometer get into the danger zone relatively easy if I kept my foot on the throttle while climbing a grade.
Second, I see on the left panel below the window a couple of air controls. I would imagine one is for the axle interlock and the other one most likely a brake limiting control. The axle interlock will make the front and rear drive axles turn at the same speed. You can still get stuck on soft or slick surfaces but it isn't as likely as if you had a drive and a tag axle. Do NOT use the interlock on dry pavement or engage it while the axles are turning--that is a good recipe for breaking axles or grinding gears in the diffs. It is about the same as running in 4wd on dry pavement. The brake limiter takes away about 60% of the air pressure from the front axle. It is supposed to keep the front axle from locking up when you are on a slippery road. I think you will find that 99% of the time it is best to keep it on the dry road position.
If you don't already know how to take care of a heavy duty diesel you would be a good idea to get a shop manual so you will know what needs to be done. Probably the most important thing to know is to keep the pH as neutral as you can get it. You should have a water filter somewhere, most likely in the driver's side engine compartment. It will have an additive package in it. That needs to be changed annually whether the engine has been run very much or not. The additive helps big time to curb electrolysis in the engine.
I don't know if your Road Ranger has OD or not. If you don't have OD and want OD you can swap almost any other RR that has OD in with very little modification. Redline should be 2100 and you shouldn't pull below 1500. Perfect cruising speed should be around 1700.
Good luck and happy trails to you.
AlleyCat67 11-03-2016 02:09 AM
Ohhh but I do love me a good RoadRanger tranny..... I'm guessing that's a 7 or a 9 speed? I didn't see the shift pattern decal in the photo but I also didn't see the flipper switch on the left side of the shift knob that the 13 and 18 speeds have....
M1031A1 11-03-2016 04:54 AM
This is what my bus aspires to be...........
Brewerbob 11-03-2016 07:37 AM
Oh I like!! Didn't recognize the name so I thought I stop by to see if there were any pictures. That isn't a school bus from any school I went to!! I only recently found this site so wasn't expecting anything like your bus on here. Good to see I was wrong.
So, if you don't mind answering, how much did it set you back? How many miles are on it? What maintenance is needed right away and what will that cost?
I'd love to get into something like this.
Lokeasy 11-03-2016 08:51 AM
I was thinking about getting a pyro because water temps can't be a good gauge of engine temp in something this size. I'll change the water filter/additive immediately. I have a little experience maintaining my f250 with a 7.3 powerstroke, but I imagine this is going to be a great bit different.
I cruise it around 1700, but the speedo is not working so I'm not sure how fast I'm going (should be about 70-75 judging traffic)
All that said, this is a really informative post and I really appreciate it. I have a lot to think about.
Lokeasy 11-03-2016 08:55 AM
It is effectively a 9 speed, since low range with the flipper down is only for starting on hills or creeping around parking lots.
R 2 4
L 3 5
Lokeasy 11-03-2016 09:07 AM
It really wasn't bad. I bought it for 15k. The PO used it regularly and was also a full time truck driver so he knew the ins and outs of what the vehicle needed to be maintained, so its good to go as is. He replaced the water lines with PEX, the flooring as well because the old lines broke and flooded it last year.
I don't know the mileage, the speedo is busted. The previous owner thinks it was rebuilt not long before he bought it(a couple years ago), and it runs that way. No smoke at start up, a little oil leak while the seals expand, and it burns a pretty typical amount of oil.
Some complaints-
The insulation is terrible, it will have to be fixed before the next Texas summer (plus sound insulation is very much needed)
A working speedo would help with gear selection in traffic
No leaks, but the roof looks like it was sealed with flex seal.
The AC units are loud
All in all, I feel like I have a great foundation to start with.
Brewerbob 11-03-2016 09:32 AM
Maybe because they are so big or because the RV dealers charge so much, I keep getting surprised by prices I'm seeing here. It's a commercial bus. For $15k it should need an entire engine and an exterminator to remove the herd of possums living under the dash.
So (knock on wood), barring exploding transmission and imploding turbos, you're fairly good to go mechanically.
Some complaints-
I think I'd be ok with that herd of possums for $15k as long as they didn't eat all the wiring. Or maybe I just need to get off my ass and start seriously looking at ads, auctions, whatever.
I'd want at least an odometer. Speedo I could take or leave. Working odometer is a must as a backup to the fuel gauge. My Dakota has a random fuel gauge. I ran it out of gas at 3/4 of a tank. Trip meter was spot on but I thought the now-ex might have driven it and put half a tank of gas in it and not reset the trip. No engine codes for low fuel pressure or anything. I was about ready to rip the engine apart for a broken timing belt. Luckily I dropped the fuel pump gasket into the gas tank. I reached in and pulled it out. Hey, wait a minute... my hand isn't wet. :facepalm:
Does it have a tach? No need for a speedo for shifting. I do that by sound. Doesn't matter if it's a 5 speed or 6 speed (auto), half the time I'm shifting to only find out I'm out of gears.:whistling:
Mayhaps, I'll peruse the classifieds section today.
Lokeasy 11-03-2016 10:40 AM
The tach/my hearing works just fine, so I don't need the speedo for knowing when to shift. More for finding a gear when I have to slow down immediately in traffic and can't work my way down through the gears. Or in other words, when I pull out of gear at 50 mph, slow down to an unknown speed due to traffic/lights/UFO/etc... then have to put it in gear and move forward at what could be 15-30 mph
I see a gas gauge on there, and it works, but I do not trust it for that exact reason. One day I'll get a new one with a better sending unit...maybe
And I'm very afraid of exploding turbos, so I'll get a pyro sooner than later.
cowlitzcoach 11-03-2016 02:36 PM
What is wrong with the speedo? Usually it is an easy fix with a new drive cable if it is a mechanical gauge. The most likely location for the drive cable would be on the tail shaft of the transmission. Many times in order to get the right speed reading there will be a little transmission on the speedo gear. Over time the case on the speedo transmission will break and fall off rendering the speedo inoperative.
If it is an electric speedo it will have a magnet driven off of the left front wheel.
It might be less expensive and a lot easier to install a GPS that will also have a speed and distance function.
Brewerbob 11-04-2016 12:39 PM
Good call. Not sure I would have thought of that. Why do it easy and cheap when there are knuckles to bust?
deftone 11-05-2016 06:47 AM
That is an awesome looking coach! Good purchase!!
I should stop coming into the welcome section as I frequently get green with envy at everyone elses purchases!!
