-   -   Need Input on Rivets (http://www.skoolie.net/forums/f13/need-input-on-rivets-16637.html)
EastCoastCB 02-02-2017 04:17 PM
I'm looking for someone who's knowledgeable on the subject of rivets to answer a few questions.
Where can I get some locally (central Fl)?
What grip range should I be looking for if I'm riveting 14 ga to 18 ga with maybe an overlap of 18 ga on some edges?
IDK, I'm trying to have everything ready for this roof raise and its suddenly hard to get ahold of supposedly common things I NEED.
Looking for 1/4" CLOSED end blind rivets in steel, not aluminum.
THanks for any help, folks!:Thanx:
slaughridge85 02-02-2017 04:27 PM
Don't know if you have em down there in FL but there's a company called Fastenal that should have any rivet you would ever need. They're usually pretty decent on pricing too...
-edit- there's a fastenal in Taveras over by lake dora
EastCoastCB 02-02-2017 04:28 PM
I checked their catalog, but alas they do not have what I'm looking for. I NEED quarter inch, and its a sea of three sixteenths out there in rivet land.
Another question-
How many cleco's do I need to do a skin job after the roof raise??
family wagon 02-02-2017 05:47 PM
It seems to me that open-end aluminum blind rivets can be had anywhere, even at most 7-11 convenience stores. But when you make the jump to steel and solid or closed-end blind, suddenly nobody stocks them. I don't usually have trouble finding things in the Salt Lake City area, but solid rivets are one thing nobody knew where to find here.
I've been treated well by Hanson Rivet in CA and Jay-Cee Sales & Rivets aka Rivets in Stock in MI (despite the latter being poorly reviewed elsewhere here on skoolie.net). Unfortunately both are not exactly "local" so hopefully you've got some timeline to spend on shipping. I tried to find something in WA for you, just to get diagonally opposite of FL... :hide: kidding!
As for clecos: I have a pair of 4x10 foot 16 gauge sheets hung on my bus with 4 clecos each. They've been like that for about 5 months now.. They're strong enough to carry the weight. Add more clecos in proportion to the level of concern over having ripples showing up in the metal, whether there's any adhesive or seam sealer being applied which needs to be clamped down quickly before it sets, etc. As I recall aaronsb had a picture on his Broccoli thread wherein the whole sheet was held by a whole lot of clecos and he heated (or mechanically stretched?) the panel to ensure it would stay flat. If one were super concerned about the fit, or had complex contours to deal with, it might make sense to go to the extreme of using a cleco in every rivet place then swap them out for rivets one at a time. You'd also need to add more clecos if you want to position more than one panel at a time. In a nutshell: I'd guess at least 20, up to maybe 50 or so. Those 1/4" clecos are priced crazy, though... you might consider using 3/16" clecos and drilling the hole bigger when it's time to install the 1/4" rivet. My personal stock is (I think..) 25 of the 3/16 and 5 of the 1/4.
Regarding length: I figure you've got .075 and .048 inches for the two sheets if they're pressed tightly together plus another .075 for the occasional lapped sheet. That's .200 inch. I'd look for something with a minimum grip around there and probably maximum grip as much as I could get. Loosely-held panels could have a gap of .050 or more between them until the rivet starts pulling together.. I think you'll need something with maximum grip of at least .300 to be comfortable, and more if you're using seam sealer or adhesive in the stack-up. Having to pull a long rivet is mildly annoying, but having the rivet too short to hold reliably is Really Bad.
EastCoastCB 02-02-2017 05:52 PM
I see. Did I mention I'll be using the HF hydraulic riveter?
That's why I bought it- it will do 1/4" rivets. At least I won't be doing them all by hand!
I'll order 20 clecos and go from there, thanks a ton. None of the fastener suppliers return my calls or emails, its getting frustrating.
ANyone coming to the bus gathering got the stuff for doing solid rivets? I'd consider that route, too, idk.
I just gotta get this all sorted out.
family wagon 02-02-2017 06:05 PM
Keep an eye on the grip length vs actual length. With a blind rivet the overall length should be a fair bit longer than the grip length -- it'll be grip length plus diameter of the mandrel ball plus thickness of the closed end plus a bit of material to get a good deformation. I'm not sure whether the blind type are sold by grip length or actual length.
EastCoastCB 02-02-2017 06:11 PM
grip length I think.
Tango 02-02-2017 06:31 PM
I've had good luck with Marson rivets, service and advice.
ourmefa 02-02-2017 07:15 PM
Let me check here in Nashville. There is a ton of sheet metal work and bus work done here surprisingly. Can you send me via email the exact specs of what you are looking for?
I have to go to the bolt supply house that I use tomorrow and there are 10 fastener companies in a small area nearby. They will be able to tell me how hard it would be to find here locally.
EastCoastCB 02-02-2017 07:19 PM
I need 1/4' all steel blind CLOSED END rivets with a grip range of .125-.250 (I think!).
Probably need about 500... I need to go out and get a count.
