-   -   How to change hub oil (http://www.skoolie.net/forums/f37/how-to-change-hub-oil-17971.html)
Qya1991 05-22-2017 09:50 PM
How does one change the hub oil on 1999 international 3800? And should I clean them out before adding the new oil? And how often should I change the hub oil? Any info will be appreciated.
Sent from my SCH-I545 using Tapatalk
Robin97396 05-22-2017 10:21 PM
"Changing oil on turbo lube (oil bath) hubs" on youtube.
I haven't viewed that video and others may be better.
JDOnTheGo 05-23-2017 08:13 AM
I've never changed it but overhead several discussions about it. Basically, you just drain it out and refill. Some guys report using one of those turkey baster suction bulb things to pull out the old oil. The type of hub may matter, I don't know.
I stopped researching it when I learned that it only needs changed VERY rarely (like 100k miles, or something like that).
