-   -   Newbie: First Post, Bumpers on the Schoolies (http://www.skoolie.net/forums/f13/newbie-first-post-bumpers-on-the-schoolies-18648.html)
Freedom30 07-25-2017 01:26 PM
Hi everyone,
New to the forum, been looking around for awhile but decided to sign up now as I will be starting my own conversion soon, looking for a 04 or newer, dog-nose, 72 passenger with MaxxForce DT466E at the moment.
First post is looking into a new bumper :/ lol
I tried google and this site but no luck.:banghead:
Does anyone have pictures of different bumpers on their schoolie?
I'm ultimately looking to put a 'Moose Mangler' or 'Civic Smasher' from a 18wheeler on the front, I've seen rigs with bus hoods on them so i thought it should be bolt on or workable.
-Equ :Thanx:
Brad_SwiftFur 07-25-2017 01:47 PM
The MaxxForce engines were '07 and up, I believe (or close to that), and have a lot of emissions parts and systems on them. IH had a lot of trouble with them and eventually discontinued them and switched to Cummins engines, if that tells you anything. These engines are best avoided. Look for an older DT466E that is *NOT* a MaxxForce, which will not have the problematic emissions.
As for your bumper, you are probably looking for a "Grill guard" (Elephant Killer, as I called my last one). For an IH bus, it should interchange with the IH 4700 straight-truck chassis (someone correct me if I'm wrong on this). A quick Google search using "Truck grill guard" might be what you are looking for.
Freedom30 07-25-2017 02:39 PM
thanks! I was looking at the Maxxforce because I thought they were more up to date and powerful, the other option was the older 466 mechanical so i could run veggie oil.
that will narrow down my search thanks again
Rusty 07-25-2017 02:47 PM
You will want non-electronic engine, like mechanical DT466 found in older bus. Much simpler. WVO is a tough route, I've been told.
MaxxForce suck bad.
