-   -   Hood badges (http://www.skoolie.net/forums/f37/hood-badges-18868.html)
AdventureBus 08-14-2017 10:00 PM
Hood badges
Best way to remove hood badges for painting bus. Are they pinned, bolted on or just glued on? 2000 International 3800, Dt466e. I can see the International one seems to be bolted but not sure on the others.
Rusty 08-14-2017 11:35 PM
Slide a thin putty knife under the edge- don't pry upward go side-side, just see if its self adhesive foam you can cut thru. If you hit a pin or screw, you can feel it in the blade.
Phatman 08-15-2017 09:41 AM
Like Rusty said with a putty knife. Just add WD-40 with that putty knife. If it is adhesive, it will soften if up and pull off pretty easily.
cadillackid 08-15-2017 10:04 AM
my hood has 2 holes on each side where if I had a logo plate it would attach. im guessing it goes through the hood and has 2 Hat-nuts on the back side.
warewolff 08-15-2017 12:42 PM
International is not bolted. It has two little pegs that sit in the hood and the rest is glued down. Pry it off slowly with a knife or screwdriver.
Tango 08-15-2017 12:57 PM
In the '60's, people used to have fun with the 100/200 series Dodge trucks. You took off a "D" and an "E" on the front of the hood then rearranged the remaining big chrome capital letters to spell..."DOG". And yes...occasionally you would see one claiming to be "GOD".
Rusty 08-15-2017 01:08 PM
Badges???
ďBadges? We ainít got no badges! We donít need no badges!
I donít have to show you any stinking badges!Ē
https://www.youtube.com/watch?v=VqomZQMZQCQ
