-   -   How to remove air door?! (http://www.skoolie.net/forums/f10/how-to-remove-air-door-18901.html)
TheRoanBus 08-17-2017 07:11 PM
Hey!
So I recently removed the air door and I forgot about the air line which hizzes out air when I turn on the bus. How do I close the line?
Thanks.
Brad_SwiftFur 08-17-2017 07:36 PM
Cap it off with a common brass fitting.
*Quick hack* fold the plastic line in half and secure with tape, rubber band, etc. This is not a long term or approved fix; it is intended to get you out of a jam.
milkmania 08-18-2017 07:52 AM
If it's all copper tubing like mine...
You can cap it off with a brass coupling and cap
Or cut it, crimp it, and braze the end closed.
golfersmurf57 09-30-2017 02:48 PM
Trace it back to source pull the line and fitting then buy a plug to fit the hole in the valve - permanent fix
Sent from my LGL64VL using Tapatalk
