-   Forum Admin | Account Help | Suggestion Box (http://www.skoolie.net/forums/f12/)
-   -   We need more time before being automatically logged out!! (http://www.skoolie.net/forums/f12/we-need-more-time-before-being-automatically-logged-out-19190.html)
RomaniGypsy 09-11-2017 08:24 PM
I haven't timed it, but more often than not, I'll finish a post and not be able to post it because when I hit "post", I get the screen that says "you have to be logged in to do that"!
There is obviously a clock, and after a certain amount of "inactivity", you get logged out. While I understand the safety aspect of this, it's set much too short. It needs to be extended to at least an hour... and frankly, I'd prefer a day... but anything would be better than the 10 or 15 minutes we get right now. (When I have to Control-C a post that isn't even 1,000 words long, to make sure I don't lose the whole thing when it says that I have to log in again, there is a problem in the programming.)
somewhereinusa 09-12-2017 05:42 AM
I've never been logged out on computer or phone.
bansil 09-12-2017 05:50 AM
X2 never been kicked out in like 5 years? Maybe a modem setting?
cadillackid 09-12-2017 07:40 AM
yeah if you start a post then walk away then submit, the session timer times out... ive had it happen before.. you stat logged into the forum, however the session timer on the form submit times out.
if I walk away from a post then come back to finish it then i simply CMD-A, CMD-C it to copy it then if I get nailed, I simply paste it into a refreshed window and post it...
joeblack5 09-12-2017 08:28 AM
Yes that happens here to. write multiple small post , that gets your count up as well:rolleyes:. seems to happen a lot.
I think that if you click "stay logged in" then it became a it better for me.
It has been mentioned before.
Later J
Rusty 09-12-2017 09:40 AM
Protip
Whenever you spend some time on a response/reply/post, select the text and copy to your computer clipboard. At least you won't have to type it all again.
RomaniGypsy 09-12-2017 09:59 AM
That's what I've been doing. The hassle of having to log in again is still real, though.
For what it's worth, maybe y'all need more information. I'm using the latest version of Firefox on a MacBook Pro running OS X El Capitan, and I have it set to its most private settings. No cookies, no storing the history, no large cache, no storing temporary files for long periods of time, none of that. (Firefox runs poorly enough as it is, without all of that junk!)
I'd say that I get about 15 minutes of "inactivity" (which seems to mean "changing web pages") before getting auto-logged out. I can be typing and that still counts. For example, I'll be able to put up this short post without problems. But if it were three or four times its length (not hard for someone like me who always has a lot of questions and can type relatively quickly), I'll have to copy it because I will have been auto-logged out in the meantime before being able to post.
Rusty 09-12-2017 10:37 AM
I never get logged-out. Running El Capitan 10.11 on i7 hackintosh. I am using Chrome, however.
family wagon 09-12-2017 11:52 AM
I wonder if it has to do with clicking the "remember me" check box on the login screen -- maybe if you check the box when logging in the session time-outs won't happen.
Janet H 09-12-2017 05:39 PM
Click remember me when you login and make sure that you have enabled cookie exchange with the site. We use cookies to keep you logged in. Another benefit of always logging in is that you see fewer ads ;)
