-   Cummins Drivetrain (http://www.skoolie.net/forums/f39/)
-   -   Engine swap 1997 Bluebird TC2000 (http://www.skoolie.net/forums/f39/engine-swap-1997-bluebird-tc2000-19275.html)
ApeWriter 09-19-2017 03:03 AM
We're doing an engine swap starting this Friday. We'll start by pulling the 5.9 Cummins 6BT engine out of the bus. We'll then pull the (same) engine out of the truck, and we'll install the truck engine in the bus. I'll post pictures and updates here as we go. Wish us luck!
http://www.skoolie.net/forums/member...cture16967.jpg
http://www.skoolie.net/forums/member...cture16969.jpg
http://www.skoolie.net/forums/member...cture16968.jpg
Jacob 09-19-2017 06:45 AM
Good luck! Does the truck have a manual transmission or heavier automatic? May be worth putting the whole set-up in your bus while your that deep. I'm assuming the bus has the 545. It's not horrible but also not ideal for road trips/pulling.
turf 09-19-2017 10:59 AM
times 2 on pulling the trans with the motor.
if its the at545, there isn't anything supporting the trans except the motor. there are a 2 cables, and the driveline that are attached and then the motor.
good luck, take lots of pictures, it will be interesting to see the differences in the motor.
EastCoastCB 09-19-2017 11:18 AM
X3 on the tranny upgrade.
ApeWriter 09-22-2017 05:59 PM
I promised the transmission to a rat-rodder in exchange for his help with the engine swap.
Jacob 09-22-2017 06:57 PM
Sounds like a worthwhile exchange you tackling the swap this weekend?
