-   Cummins Drivetrain (http://www.skoolie.net/forums/f39/)
-   -   Allison 2000 vs 1000 (http://www.skoolie.net/forums/f39/allison-2000-vs-1000-a-19343.html)
pengyou 09-23-2017 11:08 PM
The Allison has a lower 1st gear and a higher 6th gear (second overdrive) Will a 40' re type d skoolie ever be able to take advantage of the 6th gear - maybe on flat land? With 4.11 gears in the rear, will this setup have enough power for starting up, especially pulling a 4,000 pound trailer? Can the first and second gears in the 2000 be changed, lowered to allow for better performance in town? Or would a supercharger installed on the engine (in addition to the turbo) allow the engine to have more power at lower rpms?
cadillackid 09-24-2017 10:12 AM
if you want lower first and second gears you likely want to use an allison 2500 wide ratio (2500 PTS is the school bus model).. it gives you a 3.51 / 1.90. first / second ratio instead of a 3.10 / 1.81
