-   -   Roof raise help? (http://www.skoolie.net/forums/f13/roof-raise-help-21336.html)
PNW_Steve 02-24-2018 01:57 PM
Roof raise help?
Hey Everyone,
I am sneaking up on roof raise time on my 2002 Bluebird A3RE.
I feel comfortable with part of the process but would really like to hire someone who has raised the roof on a Bluebird before or similar experience. Swapping labor would be even better.
If anyone here has interest in giving me a hand speak up.
My tentative plan is to get it to the point where I am ready to start cutting hat channel and then either bring the bus to you or bring you to the bus.
I am located in Dayton Washington. We have plenty of accommodation for guests. Two spare bedrooms, a travel trailer and a Best Western within walking distance.
Anyone have interest?
Thanks.
S.
PNW_Steve 02-26-2018 12:06 PM
Anyone?
Comments or suggestions?
Thanks
PNW_Steve 02-28-2018 12:15 PM
Well.....
Anyone have any recommendations for an individual or shop they would recommend to give me a hand? Hopefully somewhere in: WA, OR, ID, MT or NorCal.
I am really weak in the sheet metal skills and do need some help.
Just to be clear, I am not looking for volunteer labor. I am looking for paid help.
Thanks.
S.
Twigg 02-28-2018 12:18 PM
Originally Posted by PNW_Steve (Post 256231)
Well.....
Thanks.
S.
If you are tempted to have a go yourself, buses are nearly all flat sheets and simple curves. The only compound curves are in the end-caps.
This is way easier than you might think if you have only ever seen work done on cars.
PNW_Steve 02-28-2018 12:45 PM
Thank you Twigg,
It is the end caps that are my biggest concern.
Also, as an amateur, if all goes perfectly then I may be ok but I am ill equipped to handle problems.
Thanks again.
S.
Asetechrail 02-28-2018 12:57 PM
Hey Steve, I have never done it either but sure would be willing to help.
I donít need payment....well beer perhaps 😁
PNW_Steve 02-28-2018 01:04 PM
Thanks Kent,
Beer is not payment it is sustenance... Necessary for the continuation of life.
I may take you up on that. I am stressing over some of the sheetmetal work.
You all need to come over for dinner soon.
Take care.
S.
Twigg 02-28-2018 05:16 PM
Originally Posted by PNW_Steve (Post 256247)
Thanks Kent,
Take care.
S.
If you end up stuck ... the biggest issue is where to make the cuts. Some help with deciding that would go a long way. Hiring a local welder to make the joins would be a much easier task .... the guy would probably make the cuts too once he knows where you want them.
BurlKing 02-28-2018 05:35 PM
i'll do it if you get it to MN, Steve. :thumb:
Jolly Roger bus 223 02-28-2018 07:41 PM
Make the cuts in the window areas that way your only dealing with putting straight pieces back together and raise the end caps with the roof or at least the rear end cap and transmission the front lower roof end cap up to the new roof.
I know you can find side windows to fit but if you raise the front end cap I don't know if you could find new windshields.
Cut a small piece of rib and take it to a sheetmetal shop and have them make pieces to fit either inside or outside of yours and depending on the height of your raise I would make them full length to lap over the cut ribs as much as possible except leave the welder an inch or two at the top and bottom to weld the ends up.
Get yourself a mig welder and practice with scraps until your omfortable in the vertical position that the ribs are going to be in
I have never done a SKOOLIE raise but i do welding and metal work for a living.
I think ECCB documented his roof raise.
Don't be scared of it. If you want it you can practice a little and weld it yourself.
Good luck
