Seeking advice for NV legalities
My boyfriend and I are residents in the state of NV looking to do bare bones minimum bus conversion to start. We need to make a short bus liveable and legal by May. After that we will worry about the cosmetic appearance but we are willing to rough it in order not to sign into another lease with our apartment. We are desperately seeking any advice on how to dp this with our time frame and a small budget. If anyone has any advice we would greatly appreciate it. We are ready to start living a different lifestyle.
You can build out as basic as you like, but you'll thank me later :) |
Agreed. Strip the interior until you see the inside of the exterior. Insulate first, then take your time.
I hope you've got shade. |
If you'd like to convert the registration, here's a pretty good outline of the registration change process from 2015. I've had recent dealings with the DMV on this topic and the outline below is consistent with my experience.
My vehicle was already titled as a motorhome in Oregon and I registered it as Motorhome in NV. I took in a weight certificate from a CAT scale and my VIN inspection with the title, bill of sale and proof of insurance. The woman asked me if it had a bed I think, an I said well of course motorhomes have beds but she did not specifically mention any list of things it had to have and the NV code specifically states: NRS 482.071 “Motor home” defined. “Motor home” means a structure: 1. Attached permanently to a self-propelled motor vehicle chassis; 2. Designed as a temporary dwelling for travel, recreational or camping use; and 3. When assembled for the road, has a maximum body width of 102 inches. (Added to NRS by 1973, 229; A 2001, 1725) RS 482.101 “Recreational vehicle” defined. “Recreational vehicle” means a vehicular-type unit primarily designed as temporary living quarters for travel, recreational or camping use, which may be self-propelled, mounted upon, or drawn by, a motor vehicle. The term includes a recreational park trailer. (Added to NRS by 1973, 229, 1585; A 2001, 1726) The DMV website states: "There are no special registration requirements for non-commercial recreational vehicles. RVs must meet pass emissions tests when required. You may need special driver license classes or endorsements for large vehicles or multiple trailers." I see nothing under Nevada law that requires a bathroom in an RV or motorhome, so there's no reason a bus remodel would require one. If they say wait, that's a bus you say it used to be a bus, now it's a motorhome. All motorhomes are RVs, but not all RVs are motorhomes. also, according to the form attached: “Rebuilt vehicle” (NRS 482.098) means: 1. A vehicle for which one or more of the following major components have been replaced: (a) Cowl assembly; (b) Rear clip assembly; (c) Roof assembly; (d) Floor pan assembly; (e) Conventional frame coupled with one additional major component; or (f) Complete front inner structure for a unibody. Note: The term “rebuilt” does not include a vehicle for which the only change is the installation of a truck cab assembly. Definitions “Complete front inner structure for a unibody” (NRS 482.0154) means the weld on structure of a vehicle, including, without limitation, the radiator support. Left and right aprons, upper and lower rails and strut towers, designed and intended to be located forward of the cowl assembly. “Conventional frame” (NRS 482.0157) means the main longitudinal structural members of the chassis of a vehicle used as the major support in the construction of the vehicle. “Cowl assembly” (NRS 482.018) to mean the forward structural portion of a vehicle to which are intended to be attached all or a part of the windshield frame, fire wall, housing of the instrument panel and hinges for the front doors. “Floor pan assembly” (NRS 482.0385) means the pans designed and intended to form the floor of the passenger compartment of a vehicle. “Rear clip assembly” (NRS 482.0965) means the entire rear structural portion of a vehicle designed and intended to be located behind the rear seat of the vehicle. “Roof assembly” (NRS 482.106) means the structural parts of a vehicle, including, without limitation, more than one-half of the vertical roof supports, the framework of the roof and the exterior metal skin that together are designed and intended to be located over the passenger compartment to form the roof of the vehicle. |
The folks in the DMV office and on the phone insist that these unpublished equipment requirements are legitimate. The reference the DMV office gave me looks like it was pulled straight out of the 2015 post. Did you go to the commercial or regular office? Did you end up needing a drive test? |
I don't think the person you talked to knew what they were talking about. I have the relevant statutes in my.phone now if anyone wants to bug me. Sent from my XT1585 using Tapatalk |
Thanks for the details!
I was *so surprised* when I read about your experience because NV is a lax state overall. It's legal to own an RPG here (although not the ammo). You can fire fully automatic weapons at gun ranges! It made no sense to me that a desert state would require a flush toilet!! And indeed the law does not have ANY requirements once I actually started to read the NV Statues and their definitions. Even if they added requirements later they would grandfather existing ones I am sure. Nevada insurance is a different matter. The insurance does, I believe, require more in terms of something being considered an RV or motorhome. As long as I can get liability I don't care, but I *am* concerned about that and I'm a little nervous about asking questions!! I wish the underwriting guidelines were available to look at so we could make decisions with the info we need. Even if I call and ask my agent, if it's not in writing, what good does that do me? Even if it's in writing, if they are wrong, what good does that do me? How am I supposed to make a good decision if I don't know what the rules are? What insurance do you have and how did you get it? I have commerical for personal use right now thru AIS.com who wrote it with Progressive, underwritten by someone else. 595/yr with the pay in full discount. Sent from my XT1585 using Tapatalk |
When I lived in Nevada I had my bus insured as an RV with State Farm. My premiums were around $300 a year for full coverage. It's been several years though. It may be worth checking.
I was at the Vegas commercial office trying to get a class B noncommercial license (Yay GWVR > 26001#!). Why the regular DMV can't handle it I have no idea; I was following what the person on the phone told me when I called. Following directions in this case didn't work out in my favor. I guess it was technically in writing since they printed it off and handed it to me, but it was word for word the same as the first post I quoted. I was (and still am to some extent) surprised to find that these requirements aren't anywhere to be found in the NAC, NRS, the Register of Administrative Regulations, or anywhere else I looked. |
