-   -   1999 Bluebird Bus International T 444 E (http://www.skoolie.net/forums/f37/1999-bluebird-bus-international-t-444-e-21617.html)
wlrogers 03-14-2018 12:15 AM
Dead Accelerator Petal
Ran fine last time it was driven. now it starts but does not have any petal just idles well.
Would it have anything to do with oil ??
Someone told me the injector pump relied on oil quality.
Dont really know where to start on this ,
Thank you william
Jdawgsfanasty 03-15-2018 03:58 PM
Thank you william
Throttle linkage? See if can rev it at the engine...sounds like a broken cable
PNW_Steve 03-15-2018 04:18 PM
I am not sure about 1999 but I know that later T444e's had an electronic throttle. I have seen the throttle pedal fail causing the symptoms you described. When it happened it threw a SES light and code.
Is your service engine soon light on?
Jdawgsfanasty 03-15-2018 07:28 PM
So you're sending a signal to a computer when you work the accelerator? So, like a rheostat?
Johnny Mullet 03-15-2018 08:58 PM
Sounds like the electronic throttle pedal failed.
Tango 03-15-2018 08:59 PM
I HATE fly-by-wire!
cadillackid 03-15-2018 09:13 PM
is this a rear engine bus by chance? if so make sure the "rear throttle" switch (if one exists) isnt turned on... if it is then the throttle pedal is disabled... the switch would be in the engine compartmnent of a rear engine bus..
id the throttle poedal has failed most likely youll see a WARN ENGINE light on your dash lit..
Jdawgsfanasty 03-15-2018 09:21 PM
I guess so...could you run a computer diagnosis then?
Johnny Mullet 03-16-2018 06:24 AM
A proper scan tool would show a code and/or show you the PID data to see if the pedal has a signal from 0-100%
joeblack5 03-16-2018 07:23 AM
Why do you not think it is a door switch or something like that. Our bus will start and idle but the throttle does nothing if not all the criteria are met. Not so likely that the the throttle pot died unless you have rodents.
Good luck,
Later J
