-   -   Picked Up A Bus, Have Some ?'s (http://www.skoolie.net/forums/f37/picked-up-a-bus-have-some-s-21688.html)
e90bmw 03-19-2018 03:52 PM
Hi everyone, brand new here. A friend and I just picked up a 1998 Thomas Vista International school bus with the T444e. We are very excited to start the process of fixing it up and converting it.
1. I am planning on doing an oil service on it but I'm not sure of the oil capacity and what type of oil would be best for it, only has 182k miles. Suggestions would be appreciated.
2. The transmission dipstick is also missing, anyone know of a good place to order or pull one? Im in North Florida.
3. What type of power steering fluid should I use? There are 3 suggested types on the reservoir but I can't actually find any of the suggested kinds for sale on line.
brokedown 03-19-2018 05:35 PM
My t444e vista takes 18 quarts of oil. Don't forget to pre-fill the filter before you put it on as wll.
e90bmw 03-19-2018 05:48 PM
What kind of oil would you recommend?
brokedown 03-19-2018 05:51 PM
Rotella all the way.
Grab a couple of these at your local walmart: https://www.walmart.com/ip/Shell-Rot...5-gal/54604946
e90bmw 03-19-2018 05:59 PM
Thank you! Any suggestions on power steering fluid?
Twigg 03-19-2018 06:16 PM
Depends on the bus.
Mine uses the same 20W40 Motor-oil that the engine uses.
Sam's, by the way, sells Rotella T4 for under $60 for 5 gallons.
I use it in my motorcycles too.
brokedown 03-19-2018 06:31 PM
I've bought the 5 gallon bucket before and as a Vista owner I can say that it's a lot easier to fill your oil with the 2.5 gallon jug!
Twigg 03-19-2018 06:36 PM
The Sam's stuff is a double-pack of 2.5 gallon jugs.
Johnny Mullet 03-19-2018 08:21 PM
I use Shell Rotella 15W40 and these engines take anywhere from 16-20 quarts depending on the chassis. Change the oil, oil filter, and fuel filter every 10,000 miles and grease the chassis every 5,000 miles. These grease fittings on the steering, suspension, driveline, and air brakes (if equipped) are easy to get to with a hand grease gun.
Probably be able to order a new dipstick through an International dealer.
brokedown 03-19-2018 08:35 PM
That's awesome then. The 5 gallon bucket I used was a real pain in the ass! I didn't have a better option so I was dipping a red solo cup to scoop oil out of the bucket and pour into the funnel. The jugs you can just pour!
TrailLifeBill 03-19-2018 08:36 PM
When I picked up my bus, I asked the mechanics what they used in their fleet. They use Delo 400, so I Googled "Rotella vs Delo" and found that in most of the forums and articles Delo rated at least as good as Rotella. Therefore, I have chosen to keep it on Delo.
2martins 03-19-2018 08:38 PM
Call your local International dealer with the last 8 of your VIN number and ask for your line set ticket. It will have all kinds of great info on your bus and they will be able to sell you a dip stick if you can't find one elsewhere and recommend what power steering fluid to use (if there is an acceptable one that isn't listed) or sell you what is recommended.
Sent from my XT1585 using Tapatalk
brokedown 03-19-2018 08:44 PM
I'm sure Delo is just fine as well. THe important thing is to use a good Diesel oil, and it helps if it's easy to acquire.
