-   -   Need help with PID 164 code. 466 (http://www.skoolie.net/forums/f37/need-help-with-pid-164-code-466-a-24159.html)
45acp 09-07-2018 04:38 PM
I have had this code for a wile, PID 164. I have a lot of smoke and now no start. :oops:
I need help. 2002 466. Where is the ICP sensor at??? Cant get any thing on line to show me where it is.:nonono:
Can any one help me find it. I am stuck and need to move the buss right now.
I hope all I need is the sensor.
Thanks.
alpine44 09-07-2018 05:36 PM
ICP = Injection Control Pressure.
Google is your friend for finding replacement sensor and instructions how to change.
rensch26 09-07-2018 06:12 PM
The ICP sensor is on the left side of the engine, towards the top. If you follow the oil line from the high pressure pump up to the oil rail you should see the ICP sensor on that oil rail. It may be slightly tucked behind your ECM.
45acp 09-07-2018 11:49 PM
Thanks rensch26. I have been a Mechanic for 40 years. And I dont see the senor any where.
And just for heads up google dose not show it ether. I will look for it in the morning. I have been trying to find this sensor for 3 weeks. Now that the buss wont start I have to find it. Thanks for the help.
alpine44 09-08-2018 10:54 AM
I would post a picture if it weren't such a pain on this site.
Look at the driver side of the engine. The HPOP is bolted to the timing gear housing towards the top of the engine. From the pump goes a pipe to the high pressure oil gallery on the block. The sensor is right behind the fitting for the high pressure oil pipe. It (obviously) has wiring going to it.
45acp 09-08-2018 11:50 AM
I found it and I unplugged it and she started. So I ordered a new one and IPR also.
Thanks.
rensch26 09-08-2018 02:10 PM
Excellent news, the Navistar ECM will use default parameters to start the bus when the ICP is not plugged in. So I would say you found the culprit. Definitely not a bad idea to replace the IPR at the same time though as they work in conjunction with each other.
