-   -   05 international brake pressure light ? (http://www.skoolie.net/forums/f37/05-international-brake-pressure-light-24189.html)
jsmitty0975 09-09-2018 08:54 PM
hello
i just bought a 2005 international ce200 with a vt365 and allison auto . it has a brake pressure light on the dash and i pulled a code 597_14p from the dash , brake lights dont work , when i jump the connector at bottem of the master cylinder brake lights work , switch is shot presumably . does anyone know a good source for service manuals and wiring diagrams ? international dealer ?
thanks for your time .
Brad_SwiftFur 09-10-2018 12:48 AM
Originally Posted by jsmitty0975 (Post 289978)
hello
I *HOPE* you researched this engine before buying. It's known to have *VERY* costly issues (mostly as the Ford 6.0, the IH version being slightly different and only slightly less failure prone.) Research some more. More than one forum member had one of these engines fail, destroying it (and a new one was quoted at around $25,000; they can't be rebuilt if they fail). These engines *CAN* be upgraded before they fail, and have good reputations afterward (at least the Ford variants, I would assume the IH versions too).
IH should have wiring diagrams for the engine/chassis, the body maker will be who provides the rest (since IH didn't build many bodies). It sounds to me like your diagnosis is spot on, judging by what I've read.
jsmitty0975 09-10-2018 12:37 PM
yes ive reseached and have worked on a fair amount of 6.0l engines it is a gamble but it does run strong and next to no blow by from oil fill . starts good hot and cold , i went through it pretty good before i bought it . ive heard so many differing experiances ( not opinions ) with these engines i figured id give her a go . if it blows ive got a 7.3 l diesl and 2 460 gas i could probably transplant if needed. called international and they want 600 . for a service manual wow . got a number from them for a guy that is suposed to be knowledgable about the wiring on busses as well . thanks : jason
cadillackid 09-10-2018 02:58 PM
the IH version is MUCH less failure prone than the ford version... no need for head studs.. update oil cooler and EGR cooler or EGR delete will solve most all of the IH issues.. never get it hot...
a couple I know has box trucks they bought new with VT and are at over over 400K on both now...
jsmitty0975 09-10-2018 04:08 PM
thats what ive read as well . and ive got 3 buddies with the 6.0l as well and they are over 600 now but thats km here 😊. the bus no idle rule should have kept it a bit healthier than most 6.0l s as well . working on some ideas to help keep it cool .
