-   -   Wiring Diagram for 2002 International 7.3 (http://www.skoolie.net/forums/f9/wiring-diagram-for-2002-international-7-3-a-25458.html)
andreap 01-11-2019 10:25 PM
hi skoolie friends!
I'm in search of wiring diagram to figure out why our starter solenoid is not getting any power :confused:
We have a 2002 International 7.3
Thanks so much!
BlackJohn 01-12-2019 06:42 AM
Can you find your starter relay physically? Pull it and clean the contact blades. Spray contact cleaner into the relay base. Then check for clean connections on the starter sol itself.
This basic circuit is common on all vehicles, so wiring diagram for anything shows the same info if one knows how to read them.
Are you looking for diagrams with power on or off?
