-   Classifieds | Buy, Sell, Swap (http://www.skoolie.net/forums/f14/)
-   -   Ď97 International DT466 Partial Conv 123k $11K (http://www.skoolie.net/forums/f14/97-international-dt466-partial-conv-123k-11k-25613.html)
Skooligan 01-25-2019 11:31 AM
8 Attachment(s)
This skoolie to be is clean, runs great, and is on its way to being an epic space for adventures! No rust, frame fully treated, cosmetic changes made. Detachable air conditioning unit, generator, and small inverter to run a laptop installed. Appliances and cabinets included. Entire mechanical system serviced less than 1k miles ago. ‘Immaculate’ in the words of the mechanic! Has the DT466 engine and Allison transmission, automatic chains, air ride seat, and even a sound system with aux. Just needs someone with plumbing and electrical skills to finish it off. Contact Jack for more info. Love2bond007@gmail.com
o1marc 01-25-2019 11:42 AM
Another 1st poster with no contact info.
If it were not in the classifieds I would not be sure if it was a sale ad.
Skooligan 01-25-2019 11:47 AM
Thank you I updated the info.
o1marc 01-25-2019 11:50 AM
What transmission is in it? Allison makes many.
Skooligan 01-25-2019 12:18 PM
Yes, I’m aware of that. I need to check the title for specifics and then I will update the thread.
o1marc 01-25-2019 03:32 PM
Originally Posted by Skooligan (Post 307118)
Yes, Iím aware of that. I need to check the title for specifics and then I will update the thread.
It's an important thing most people looking will ask you.:thumb:
Skooligan 01-26-2019 02:07 PM
So I have looked through all the paperwork and can’t find the specific transmission? Where is the model info?
PNW_Steve 01-26-2019 05:30 PM
Originally Posted by Skooligan (Post 307300)
So I have looked through all the paperwork and canít find the specific transmission? Where is the model info?
There should be a tag on the transmission with the model number.
Or, you could call your local dealer with the VIN and they can tell you all about your bus. Including engine horsepower, transmission model and rear end ratio. All good information to have on hand for potential buyers.
Tango 01-26-2019 06:54 PM
Check the tranny first (in case it has been changed out at some point). Allisons all have an ID tag like the one below. Mine was on the passenger side. Course, unless new, it will probably be covered up in grease & oil.
https://farm1.staticflickr.com/504/1...db9fe528_z.jpg
Everything you need to know you can get from Allison thru the tag.
geminusprime 01-26-2019 07:57 PM
When I went to multiple school districts, they didn't know the transmission type either, just "it's an Allison".
When I climbed up under every single one, not only did the tag show what the above image does, but it also said the type right on there - the darn 545 for every one.
So at least for some it seems, the transmission type will also be on the badge.
