-   -   turn signals work hazard lights do not 97 Ford/Thomas (http://www.skoolie.net/forums/f49/turn-signals-work-hazard-lights-do-not-97-ford-thomas-25753.html)
jprice692004 02-04-2019 06:59 PM
after disconnecting all the extra lights i have everything working except the hazard lights, the turn signals all work fine. Any suggestions would be greatly appreciated.
david.dgeorge07 02-07-2019 10:51 AM
I have the same situation so curious for response. I would like my hazards to work...
geminusprime 02-07-2019 11:45 AM
Make sure contacts are properly seated on hazard toggle connectors.
Ensure that if you have an external light monitor, that all contacts are properly seated.
Check this thread.
jprice692004 02-07-2019 04:09 PM
got them working again
I found the original fuse box, the labels were unreadable, so I just started checking fuses found one 20 amp blown, replaced with a 15 amp, and they started working. Sometimes its the simplest things.
Tango 02-07-2019 06:16 PM
Gotta love a simple (and cheap) fix!
BlackJohn 02-07-2019 07:06 PM
So changing a fuse got you power back but have you found out why it blew in the first place? I don't hink you are done yet.
How long have you owned the bus? And you never bothered to find out where fuse box was? That is the absolute first thing one should find and get familiar with.
