-   -   Allison 2000 ID (http://www.skoolie.net/forums/f37/allison-2000-id-25777.html)
Rogue1bus 02-06-2019 03:47 PM
Allison 2000 ID
3 Attachment(s)
Iíve come across an Allison 2000 transmission from another bus. The junk yard only wants $700 for it (transmission with Ecu, but not the shifting buttons).
How do I find out if itís the 5 or 6th speed version?
My top speed of my current 545 w/t444e is 55 at 2500rpm. Trying to figure out what my new top speeds would be with a 5 and speed OD?
Is this a good deal?
Iím trying to decide if I should regear the bus or change the transmission.
Thoughts?
Thanks!Attachment 29569Attachment 29570Attachment 29571
Tango 02-06-2019 03:51 PM
Contact Allison. They can give you all the details from the serial number.
Rogue1bus 02-06-2019 04:36 PM
Allison said itís a 5sp capable of 6sp.. trying to find out the final gear ratio... I think itís .74
Tango 02-06-2019 04:44 PM
For 1000 & 2000 series the following are supposed be the ratios...
First: 3.10
Second: 1.81
Third: 1.41
Fourth: 1.00
Fifth: 0.71
Sixth: 0.61
Reverse: 4.49
However, I believe there are both wide & close ratio versions. Best to check with Allison. With the serial number they should be able to tell you exactly what you have.
PNW_Steve 02-06-2019 04:49 PM
IIRC: 2005 and earlier are 5speed. 2006 and later are 6 speed.
The 6 speed transmissions in school buses typically have 6th gear disabled.
You can upgrade an earlier 5 speed to 6 speed by swapping out the valve body and reprogram the TCM.
EastCoastCB 02-06-2019 05:27 PM
First: 3.10
Second: 1.81
Third: 1.41
Fourth: 1.00
Fifth: 0.71
Sixth: 0.61
Reverse: 4.49
I know the od on a 5 speed 2000 series in a school bus is .74
Edit- you're close. Those ratios you listed are for a 1000. The 2000 series has ever-s0-slightly lower gearing.
Rogue1bus 02-06-2019 05:51 PM
Allison 2000 ID
Right on. Thanks for the replies! Iím going to pull the trigger and get it in the morning. Seems like a really good deal, supposedly it came off a bus with the same engine T444e with less than 100k miles.
Since it came off a bus with the same engine and Iím getting the transmission ECM with it I wonder if itís going to be plug and play?[emoji848]
Rogue1bus 02-06-2019 05:52 PM
Allison 2000 ID
.74 final gearing will take my top speed from 55 to 75mph, and my cruising speed from 44 to 60mph[emoji41]
Which I donít even see the point in trying to unlock 6th gear...
o1marc 02-06-2019 06:02 PM
The only reason I want 6th unlocked is for the fuel economy.:thumb:
EastCoastCB 02-06-2019 06:20 PM
OD is great but I think folks get a *little* too carried away with the whole "have to unlock 6th" thing. I get it, I love modifying stuff for more enjoyable use.
OD would be awesome!!!
This is probably THE best swap especially behind a 444E.
