-   -   Allison 2000 ID (http://www.skoolie.net/forums/f37/allison-2000-id-25777.html)
Rogue1bus 02-18-2019 09:39 AM
PS. I guess some of these other plugs on the bus side could be for reverse lights/beepers etc. That one large 8 pin plug is still puzzling me.
Rogue1bus 02-18-2019 12:55 PM
I talked to the international dealer and gave them the harness part number.
They told me the harness is compatible with 3200 series buses that were equipped with dt466 engines.
I have a bluefire j1939 code reader so I知 feeling pretty confident I will be able to make this harness work despite it being designed or a different engine.
Rogue1bus 02-19-2019 03:00 PM
1 Attachment(s)
I ordered the wiring harness today. Hopefully I値l be able to get it to interface with my t444e.
Attachment 30070
This I知 my TCM, I知 banking on my ECU being capable of sending throttle info to the TCM... if not I値l need to find a work around.
cadillackid 02-19-2019 04:14 PM
Your throttle will send from that 3 pin connector I described, you need to reprogram the ECM to make the Speedo and cruise work correctly and not throw codes.
Christopher
cadillackid 02-19-2019 04:18 PM
I値l have to see if my oncommand has the pinouts for all those connectors, it should since it covers those years. You may have to add some wiring in the chassis side as it may not be there by default.
Christopher
inhof009 04-11-2019 05:56 PM
Originally Posted by Rogue1bus (Post 310696)
Chesapeake and Newport News va
Rogue,
What scrap yard(s) did you go to? I'll likely be trying to poke around some scrap yards if not just for fun.
Rogue1bus 04-11-2019 06:45 PM
1 Attachment(s)
Originally Posted by inhof009 (Post 319441)
Rogue,
Rudy痴!
Attachment 31797
